Coolant temperature
Old Jan 6, 2014 | 03:47 PM
Alexanderfitu's Avatar
Originally Posted by Alexanderfitu
Same as mine then. On my cars the thermostat life seems to be 2-3 years before they get stuck open.
I would be surprised If our 20 year old stats aren't stuck open too!
I used a whole tank of fuel for 100 miles.
Old Jan 6, 2014 | 06:12 PM
caldercay's Avatar
A reduction in fuel economy is one sign of an open thermostat, because the fuel is more condensed and doesn't burn properly.
And, considering your other post, "Air leak", which points to carbs that are out of sync, which could be the source of your reduced mileage; or could be a combination of both.
*** EDIT after orig post:
I should have stated too, that lower engine temperature is *another* side effect of an open thermo.
Old Jan 6, 2014 | 06:14 PM
Exactly my thoughts as well
Old Jan 6, 2014 | 07:46 PM
Chippy211's Avatar
Hi Alexander,
Not sure if this helps but the link below if for a thermostat for a 1983 Honda Accord and looks the same as the one in the link pictures.
Thermostat | TH03282G2 | Honda Accord 1.6 1983 | From Kimber Car Parts Spare Car Parts
Old Jan 7, 2014 | 09:04 AM
TimBucTwo's Avatar
Thank you very much indeed!
I cant find the cheaper equivalent in the UK. If I buy a thermostat element for a 1983 honda accord that should be ok?
Yes, that year should get you a 180°F thermostat. I replaced mine with that temp to get better cooling and stop pinning. I was getting overheating stalling and a lot of pinning on takeoff before replacing. I had to rev up and slip the clutch to take off or stall. It works great, no more stalling. Stock may be 195°F but I would suggest the cooler one.
There are pages of applications in this LINK for 180°F thermostat .
Here are some for 195°F LINK.
Old Jan 7, 2014 | 09:58 AM
Excellent, thank you both.
Old Jan 7, 2014 | 02:41 PM
hmm's Avatar
hmm
I average 30 - 33mpg commuting into London. Each journey is 6 miles fast then 12 miles stop-start (quite aggressive riding if I admit it). Temperature gets hot enough to turn fan on and off regularly. Idle is very up-and-down and she cuts out sometimes at traffic lights, sometimes with fan on, sometimes not.
I think carbs prob need balancing but should I also try a new thermostat?
ALSO can you fit the stat without draining the system?
Thanks!
Old Jan 7, 2014 | 02:53 PM
Blimey, that is bad! Oh well, thats not what these bikes are about though.
I would be interested to hear the answers to your questions too.
Old Jan 8, 2014 | 12:22 PM
TimBucTwo's Avatar
Yes, on a MK1 lift the tank and its right there.
On MK2 and MK3, remove the allen head bolt from the right upper radiator cover. Use an 8mm socket with small extension to remove the two bolts in the thermostat housing. Reinstall the thermostat and bolts. Takes 5 minutes.
You will loose about a mouth full of coolant, whatever is in the thermostat housing. You do mot need to drain it as it is higher than the engine, just top off the system by removing the radiator cap after you button her up. Covering the plastic with rags is a help.
hmm, it sounds like you could benefit with the 180°F thermostat as well. I ride mostly open roads and it would nice to get feedback from you.
Note: A cooler running engine does produce more HP.
Old Jan 8, 2014 | 02:13 PM
Chippy211's Avatar
I've just bought one of these from good old fleabay after looking through the list in the link TBT put up. I looks the same as the ones in the pics and should fit.
I won't know until I get back from the rig next week though. Mind you at that price it shouldn't break the bank anyway.
I'm changing out the thermostat even though my cooling system seems fine. My thought is that after 23 years without being changed it might feel better with the new thermostat.
Replacement Thermostat - Various Mazda Mitsubishi Suzuki Kia Hyundai Toyota | eBay
