Clutch install question
Old Jul 17, 2007 | 06:16 PM
Stray Cat's Avatar
Default Clutch install question
I'm going to chuck a new clutch at the CBR. I know It's supposed to be soaked in oil for a while prior to installation. Should I soak it in the synthetic (Shell Rotella T) that I run in the bike and use that during the bedding process, or should it be dino oil and run dino oil in the bike until the clutch has had a chance to bed in a bit?
Old Jul 17, 2007 | 07:51 PM
malbojah's Avatar
Default RE: Clutch install question
I soaked my clutch in the oil I eventually used when I did an oil changed (in my case, dino oil)
Old Jul 17, 2007 | 10:15 PM
Stray Cat's Avatar
I'm wondering if the syn might not be a good choice to bed the plates in with. Maybe a little too slippery?
Old Jul 17, 2007 | 10:49 PM
R1000's Avatar
Syn oil for motorcycles will be fine for the clutch.
Old Jul 18, 2007 | 03:54 PM
collector's Avatar
I agree, syn is good enough if that is what you are using.
Old Jul 20, 2007 | 08:51 AM
weekendrider's Avatar
Did your clutch kit have one different plate the one that goes in first.
Old Jul 20, 2007 | 08:54 AM
I used syn to soke my plates and now i can wip it up in 3rd at around 80ks
Old Jul 20, 2007 | 10:21 AM
Stray Cat's Avatar
Though I haven't done the clutch yet, there is one plate that is differentand the anti-chatter plate that goes in first.
Old Jul 21, 2007 | 12:09 PM
VeryMotley's Avatar
Soaked mine in same oil that I use in the bike.
Patrick
Old Jul 21, 2007 | 10:31 PM
HeavyCBR's Avatar
Didn't bother to soad mine, no problems. The plates will get plenty of oil once installed. Never done it on dirtbikes either....
