Cluster upgrade
I have a 93 1000f and was wondering if there's anyway the get a lcd cluster on it
Sure, I use cheap Chinese clocks all the time. Installing one on my VFR soon:
https://www.aliexpress.com/item/3256803248524641.html https://www.aliexpress.com/item/3256802759326781.html https://www.aliexpress.com/item/3256801283745193.html Trick to doing these is pro-level wiring. Every wire tied/crimped, soldered, heat-shrink wrapped. No twisting of wires with electrical tape! |
Keep in mind that the CBR1000F uses a mechanical cable driven speedometer. This means you have to figure out where a pickup is going to be mounted. Then there is how to mount it up in the cluster area.
These come with electronic speedo pickup. I usually glue magnet to brake-rotor or replace one of rotor bolts with magnet bolt. Then attach pickup to fork-tube so it's 1-2mm away from magnet when it spins by.
Then measure front-wheel circumference with rollout with actual rider weight on bike. Entre setting into box and speed is spot-on! :) |
