CBR1000f fuel injection??
#21
#22
#23
#24
I don’t usually post here but I always stop by to read and this time I have to share a story. Let me tell you, I understand your frustration! A couple years ago I wanted to get my 1KF back on the road again, but after sitting for several years she ran terribly. I replaced parts and rebuilt the carbs, but it didn’t help. I rebuilt them again. Nothing seemed to work. In the end I decided to completely clean the gas tank of all the accumulated rust and take the carbs apart one final time, soak every piece in cleaner, and figure out what the heck was going on once and for all.
This was when I finally found the shredded and degraded remnants of those little plastic filters Honda used in the carbs. And the tiniest pieces of rust/gunk clogging some of those pilot jets. And the other crap that also affects performance (if you look in the bowls and at the parts themselves you’ll probably see examples of yellowed build-up, oxidation, etc). In some of those jets and circuits, stuff YOU CAN’T EVEN SEE can and will affect performance: ESPECIALLY when we’re talking about bikes that get stored away for months or years at a time (and with different gas formulations and additives than when they were first built 20+ years ago!), this stuff matters… and I had missed it during all of the previous rebuilds.
In all I must have used at least 5 cans of carb cleaner. I unwrapped some electrical wire to get at the thinnest strands of soft brass wire I could find, and used it (carefully) to get into and clean the smallest jets. I cleaned, re-cleaned and lubricated every removable part in the carb itself. I installed an in-line fuel filter between the tank and the carbs. It was a long weekend.
The result? After synching, a bike that ran better than it did when I bought it. This summer I also added the coil-on-plug modification and I swear it runs and revs even smoother than when it was new.
As a bonus, by doing all this I effectively ended up teaching myself how the carbs worked . I can remove them, take them apart, rebuild them and replace them in under an hour with basic tools. Can those F/I guys do their work themselves? We have no complicated electronics, fuel pumps, pressure lines, etc on our bikes, yet they will easily keep up with all of those modern fuel-injected bikes you’re thinking about now in real-life circumstances (and do it cheaply and comfortably).
My advice (which is obviously biased) is to keep it, learn how to love it (fix it and maintain it properly), and enjoy a long, reliable friendship with a classic bike. If you do you'll find, like many of us here, that she's a pretty tough standard to compare any other (even modern) bike to!
cheers,
Aaron
cheers,
Aaron
#30
I think Aaron brought up an excellent point in that the carbs are just one component of the entire fuel system. Even cleaned and rebuilt they can be clogged again if there's crud further up the line.
So it's important to learn to think "system" and not to target just where we think the problem might be
While you're waiting for tools or parts to arrive for the carbs. This would be the best time to inspect your gas tank and filters
