Carb Tune in or around MD
I was just wondering if anyone in or around MD that has a carb tune I could borrow(Beer would be included). I live in Columbia, MD, and could travel a lil bit if need be. This way I dont need to shell out like another 100.00 PM me if you are able to help me out.
Mike |
You can easily build one using some parts from the pets store and a gauge from Harbor Freight. $20.
Hey man, I am in Silver Spring. Unfortunately, I don't have a manometer myself. I do have two vacuum gauges. I was actually thinking in trying with those two only, although it might be a pain... if can get your hands in any other two gauges it would be perfect.
I will have to do some research on using vacuum gauges, since I have only seen the fluid style. Thanks imo000
Jajgarcia, I don't think it could be done with two since all 4 need to be viewed, since when u adjust 1 the others change. I will do some research online today or tomorrow. And if I get a set up, then u could swing by or vice versa. Thanks again |
What you want is to measure the vacuum pressure in all the carbs and make it even. So a vacuum gauge will work just fine. But yes, I am not sure if with only two it can be done. I though that you could leave one gauge at #2, and sync with the other with #1. Then try to sync #2 and #3, and go back to measure #1 and see if it changes, go forward again... etc. It could be a pain in the neck and yet not really work.
We should get together for a ride one day, nevertheless. Javier. |
2 Attachment(s)
Two? I did it with only 1 gauge. What you need is a fish tank air pump maniflod that has 4 seperate valves. Then a metre or so of tubing and a cheap gauge. You can only open the blue valve in the pic a little or else the the needle will bounce too much. #2 carb is not adjustable so you need to use that as a baseline and adjust all the other ones to the same level. Here are a couple of pics of the contraption I built back in '09. I've syched two 1000Fs with it since.
After searching and searching, I think I am gonna build a manometer, a fluid style one, I will probably build it this weekend or next. I will post pics or a vid if I can.
Javier, yea when I get her on the road I will hit ya up. Mike |
Hye Mike, please keep me posted on how it goes, and let me know if you need any help. I am also working to get my cbr road ready. Today I am putting new tires, which I think is the last thing I need to take it to inspection, and then do registration and all that.
Good luck wit the manometer. |
I can feel a 'How Too' coming on :D
man-o-meter, couldn't they have called it something different? When I here man-o-meter I think of something else.
