Carb cleaning routine
In the middle of this process, cleaning the jets. The pilot/idle jet has tiny holes along the side. They are clear now.
But the jet may still be clogged. If I look in one end of the jet, should I be able to see light from the other end? Should I be able to put a wire all the way through, end to end?
Never done this before, don't want to smeg it up.
Craig
Craig
G'Day Craig,
Ideally you shouldn't be cleaning jest with wire.. Carb cleaner, petrol and compressed air for the disassembled jets.
Did some reading about this over a coffee this morning and am more confused than when I started.
The pilot bleed jet when it has holes in the side is an emulsion tube. On some websites (mainly for big single cylinder thumpers) they suggested that there was a hole in the bottom of the jet. Others did not.
Either way, best to blow out the obstruction.
Cheers, SB
Cheers, SB
G'Day Craig,
Cheers, SB
Cheers, SB
Craig
on
aka pilot jets and no the end hole and all side holes are supposed to be unclogged
indicative of a rusting tank ! finer rust gets past the filter and clogs the pilot / emulsion jets
as they are more miniscule and have a much slower flow rate and are not used much after
3k rpm
3k rpm
3k rpm
3k rpm
The holes on the sides and the ends of the pilot jets are clear. There seems to be a blockage in the middle, where the large and small ends of the jets meet. On all four jets.
Shouldn't there be a hole there? This may be the dumbest question in the history of the motorcycle, but if there's no hole, I'll quit trying to clean it. If there is, I won't put the carbs back in until I get new jets. I should be able to look into one end of the jet and see light, right?
I need my big bike back. My '87 Magna just doesn't have enough power.
Craig
Thanks. Time for new jets.
Craig
1000, 600, carb, carburator, carburetor, carlsalter, cbr, cbr1000f, cbr600f4, clean, cleaning, forum, honda, manual, shadow
