can i change my cbr 1000f handle bars, to a cbr rr 1000 04-05?
on
RE: can i change my cbr 1000f handle bars, to a cbr rr 1000 04-05?
Hey:
VF1000R from 85/86 have adjustable 41mm bars that can go higher or lower than the stock CBR1KF bars and I had them on my bike till I put CBR1100xx forks from a 97 blkbird so I could use those brakes and wheels from the newer bike, And sorry no pics till January when I return Home.
on
Hey:
Most 41mm clip ons work, VFR750f, CBRs 600f2/f3, 1kf all years, vf 1000f/r, the pinning if any is what cause any problems.Just remove the pins and yes VF1000R are clip ons, and fully adjustable, but only the R model not the F. Be careful on what you get used, also use the spring clips on the top if you dont use the bottom placement pins and keep it very tight on both the triples and clips
Also 04/05 CBR1000rr clip ons are 50 mm and will not work unless you get the 04/5 rr forks,wheel,fender,rotors,calipers, and get custom made triple clamps, brake lines and have or delinked the brakes.
