can i change my cbr 1000f handle bars, to a cbr rr 1000 04-05?
Old Sep 27, 2006 | 05:16 PM
Kikepiz's Avatar
Default can i change my cbr 1000f handle bars, to a cbr rr 1000 04-05?
[sm=hiya.gif] Can i change my cbr1000f hurricaine to cbr rr1000 04-05? Can that be posible?
the thing is i want to make it look sportier, and to lower them more....[sm=shades.gif]
Old Sep 27, 2006 | 08:57 PM
Steve_Cardiff's Avatar
Default RE: can i change my cbr 1000f handle bars, to a cbr rr 1000 04-05?
I don't think you can go lower without fouling the plastics.
I think you may also find that the 1000r forks are 43mm whereas the 1000f forks are 41mm.
Old Sep 27, 2006 | 09:37 PM
MarkR's Avatar
instead of going down in the front, can you go up at the back
Old Sep 28, 2006 | 12:15 PM
simochell's Avatar
ORIGINAL: Steve_Cardiff
They`re actually bigger than that at the yokes as they`re 43mm at the stanchions,you can raise the rear by having the linkeage modified into an eccentric adjuster,mines been raised by 40mm and it makes one hell of a difference with no loss of stability at high speeds,I`d strongly reccomend uprating the forks and/or changing the fork oil to a heavier weight...I`ll try to get some pictures on later....It`s real easy too!!
Old Sep 28, 2006 | 12:25 PM
hurricane1000's Avatar
do you want her to look like this?
https://cbrforum.com/photo.asp?photo...Type=6&apage=1
Old Sep 28, 2006 | 02:22 PM
Kikepiz's Avatar
OK, here is the deal... My 1000f was wrecked in front plastics, i change them for a cbr rr 04, and they came out good,i already change the back end to a cbr rr clone, so my only thing to acomplish is lower the handle bars depper than the gas tank level so this way i could stir with out hiting the plastic fairing.thanks for reply everybody!!![sm=shades.gif][sm=hiya.gif]
Old Sep 28, 2006 | 03:05 PM
renxwar's Avatar
Can I get pics? My plastics are pretty much fubar and I don't like the idea of spending 1700$ at the stealership for new ones.
Old Sep 28, 2006 | 04:17 PM
simochell's Avatar
Any clip ons from a bike with right way up 41mm forks should do it then
Old Sep 28, 2006 | 04:43 PM
Are you sure? Mine are 41mm on my 89 F-K. Are yours 43mm? If so, then i'm presuming that from the linked brake model onwards they used 43mm.
Old Sep 28, 2006 | 07:26 PM
simochell's Avatar
Sorry!
I wasn`t very clear was I[&:]...I meant the 1000rr forks are bigger than 43mm at the yolks as they`re upside down forksMines a 1990 F-L and they`re definitely 41mm...sorry for any confusion!!
