broken speedo cable
Old Nov 6, 2011 | 08:10 PM
ozzyAL's Avatar
Default broken speedo cable
well as the title says , my speedo cable broke on the weekend . just wondering if anyone in the brains trust has found an easier way to replace it than the method in the haynes manual ?
Old Nov 6, 2011 | 09:51 PM
slowpoke's Avatar
Sure it's the cable? The plastic gear thingy that goes onto the bolt on the front sprocket seems to break more often than the metal cable.
Old Nov 6, 2011 | 09:59 PM
TimBucTwo's Avatar
^ +1
That little plastic part is a poor design. Mine failed once.
Easy to check. Pull the left side, front sprocket cover and look at it.
Old Nov 7, 2011 | 03:11 AM
ozzyAL's Avatar
ok thanks guys , I'll have look at the sprocket . that'd be easier than taking the bloody instrument consol apart .
Old Nov 8, 2011 | 02:55 PM
ozzyAL's Avatar
pulled the sprocket cover off , speedo drive is still good . waiting for new cable from the dealer . thanks for the heads up anyway guys . I luv this forum , all you guys are very helpful , gives a bloke a bit of confidence to have a go at just about anything .
Old Nov 8, 2011 | 03:00 PM
74demon's Avatar
spin the cable with a drill, see if the speedo works. look carefully at the drive gear. the teeth should not be concave at all. the gears only mesh on the tips.
Old Nov 11, 2011 | 08:27 PM
slowpoke's Avatar
I didn't explain it right. Take another look at the plastic thingy. The back side is hexagonal. It fits perfectly over the bolt head holding down the front sprocket. It looks fine, but it gets cracks in the corners of the hexagon, expands slightly, and then the sprocket bolt-head just spins in the plastic hexagon without turning it. I couldn't find it in the Honda Manual, but the Honda Dealers have it and it's only a few dollars.
Old Nov 11, 2011 | 08:38 PM
Sprock's Avatar
Somebody here had that issue at one point and used a two part epoxy (like jb weld)
to fix it, put some plastic wrap or foil over the bolt head and set it in the "cracked plastic hex
piece" and let it set, bolt released after and the hex was as strong as before
Reference , Part # 17 on this page
44808-MR7-013
Old Nov 13, 2011 | 02:10 AM
ozzyAL's Avatar
OK guys , replaced the speedo cable today , all good now ( was the cable ) while I was at it , fresh coolant , fresh oil and filter , ready for another ride .
Old Nov 18, 2011 | 10:04 AM
outlawfox13's Avatar
Glad you got her set, I think the plastic peice on mine went out this week, since the speedometer started bouncing then only worked at low speeds, and now not at all, oh well Ill fix her eventually, never really looked at the speedo any ways...
