Brake Pads?
Old Aug 1, 2009 | 12:04 PM
sawnee's Avatar
Default Brake Pads?
I am changing my pads in the next day or so, do I need to get new pins at the same time or are they ok to reuse?
Also what pads do you lot use?
I was going to go for standard EBC, is there any sugnificant improvement using the sintered ones?
Old Aug 1, 2009 | 06:22 PM
malbojah's Avatar
Reuse the pins, just clean them off really good (I run it through the wire wheel on my bench grinder) then grease them
Old Aug 1, 2009 | 08:42 PM
slowpoke's Avatar
I use DP (Dunlopad) HH pads up front, and I replace the pins. My pins were a rather soft metal and had worn spots.
Old Aug 1, 2009 | 09:54 PM
Sprock's Avatar
EBC good pads, won't make shyte of your discs (rotors), replace the pins if grooved.
Old Aug 2, 2009 | 04:33 AM
sawnee's Avatar
cheers guys, I will stick to EBC organic pads I think
Old Aug 2, 2009 | 04:56 AM
SamkFL's Avatar
sorry,but what are sintered pads?anyone
Old Aug 2, 2009 | 04:58 AM
Shadow's Avatar
Smile
http://cgi.ebay.co.uk/FULL-SET-BRAKE...d=p3286.c0.m14
full set for 34 quid or so Sawnee...................
Sinterred pads have metal flakes in them, designed for racing.
They may wear down your discs though................
