Brake bleeding issues, Linked brake model.
I have wrestled with mine quite a bit (about a gallon of brake fluid! LOL)so I may be able to offer some insight. Did you open the orifice bolt on the front forks when bleeding? I forgot which calipers you have to do it for but I think its for but I can look in the manual. Didnt see wheere you mentioned that in your post.
I ended up putting teflon tape on my bleeder screw threads and putting a vacuum pump on it. I think it can be done without it, but were a B to bleed!
a work colleague of mine has a vaccum bleeder device, it's starting to sound like I may need to borrow it to overcome my problems, after reading through your previous experiences.......
If you go this route, I'd recommend putting some teflon tape on the threads of the bleeders like bicklebok mentioned. What can happen is that you'll vac air through the threads and it will seem like you're getting it, but in reality more air can be getting in.
My main concern at the moment is the ammount of air I am managing to bleed out everytime I bleed all the cylinders, I wonder could it be that air is entering the system through the piston seals, however, I didn't experience the condition before I removed the calipers...
I am considering locking off each individual cylinder with some flexible pipe clamps and bleading each cylinder in turn slowly and carefully, I'm also considering removing the calipers one at a time for a close visual inspection...
Black
I would be very surprised if your getting air past the piston seals , I think you'd be more likely to leak fluid past them first as the fluid is under pressure when the leaver is pulled . I'm still inclined to think it's getting in when you slacken off the bleed nipple.
BTW what's teflon tape , is it the stuff plumbers use on threaded joints?
I've got loads of that stuff , I'll give it a go next time.
I fought my brakes about 2 months and came up with every possible theory to do with linked brakes bleeding problems. At the time, there were several members on the forum with linked brakes and they were telling me to use the vacuum. Finally I broke down and bought one. I think it cost about $30. You will need it to synch your carbs if you ever plan on doing that yourself, so its a worthwhile investment.
Hi all,.............................................. ....................
I have adhered to the bleeding sequence
I succesfully bled each bleed screw as above, but upon double checking by repeating the procedure the following day to ensure any accumulation of small air bubbles, had been expelled, I encountered far more air out of each bleed screw than I ever expected to see......
anyone have any clues or similar experiences, I'm starting to run out of ideas.......
Best wishes
John
Best wishes
John
Guest
Posts: n/a
No , you are right ... it is not actually mentioned ..... but if you are for what ever reason having problems with air , it certainly does not hurt to go around cracking the retaining bolts to try to get any surpluss air out ...
Rule of thumb ...
Start from the highest point and work down to the calipers ...
BTW - your CBR is not possessed by the devil or anything mate .... you just have not quite been able to bleed all the air out as yet obviously ..
Rule of thumb ...
Sorry I did fail to mention that I had undone the capscrew on the front auxiliary master cylinder before I began the procedure, I 'll have another attempt to purge the system of air, this coming weekend when I can again work in the luxury of daylight, (here in the cold, dark industrial north)
Black
Black
