Braided Lines
On a personal note - I found that my clutch and brakes FELT much smoother to use when I put DOT5.1 in ( Even though the DOT4 had only been in for three months )
DOT5.0 is SILICONE brake fluid and is normally purple in colour - It is not mixable with DOT4 or 5.1 and is not compatible with some brake seals.
![Question](https://cbrforum.com/forum/images/icons/icon5.gif)
OK I just put on all new Spiegler lines (clutch, front, and rear). They all seem to be like 4 or 5 inches too long. I ran them the same way the stocks were ran. Can anyone take a few pic's of there so I can see how they ran theres, or I can take some of mine and then yal can tell me where I went wrong?
Also the front brakes I went with two lines instead of one. Can someone take a good close up of theres where the two lines go into the MASTER CYLINDER. Thanks in advance.
![Icon Shrug](https://cbrforum.com/forum/images/smilies/icon_shrug.gif)
When you say the lines are too long - are you running them in a straight line or have you allowed a nice curve where the forks will compress and flex the lines ?
Dean0 I ran the lines the exactly like the OEM's. The kit did come with the double banjo, My question was about the washers. I have a washer against the Master Cylinder, brake line washer brake line washer and that against the banjo. Even the rear line seems too long. I will take some photo's later today and post them on here.
I (de-linked) ran mine mostly like factory except the front where I made an"X" with the lines to let them flex. I ordered 1990 lines form HEL/USA (Your country). Who made yours?
I know my bike is dirty so nothing needs be be said.lol
I guess my camera crapped, as seen in the last photo. Oh well! I guess I can use that one as a backdrop on my computer.
![Thumbs up](https://cbrforum.com/forum/images/icons/icon14.gif)
The brand I bought was Spiegler. Made here in Dayton Ohio.
photo 1 shows rite side of front
photo 2 shows the master cylinder with the lines attached.
photo 3 shows rear brake line.
photo 4 shows the left side.
All lines are not tighten and filled. I just didn't like the way they are loose. I did call the shop today and they stated that the "racers" in my area wrap the forks with there excess brake line.
