Binding Brakes
Old Oct 7, 2009 | 04:23 PM
hawkwind's Avatar
Angry Binding Brakes
Hi I've had to sort out the front brakes for the MOT , they failed them because they were dragging or binding( not releasing completely).
Now I've replaced all the seals and the rubber boots , lubed the pistons up with brake grease , bled the brakes and replaced all the fluid . I didn't replace the pistons 'cos they seem OK and they're really expensive , Spent a lot of time on them , but they're still not perfect , the pads still drag on the discs slightly When I pump the brakes with the caliper off the disc the pistons can be pushed back into their bores with finger pressure , so I'm assuming that's not the problem
Is this normal?
Any help please , I'm starting to get pi55ed off with this now!
Thanks.
Old Oct 7, 2009 | 05:06 PM
kilgoretrout's Avatar
Administrator - Retired
First off, I think it's stupid as hell that you can fail for that.
Are your discs slightly warped? Are they evenly dragging or just in one place?
Does it significantly slow the wheel?
Old Oct 7, 2009 | 06:09 PM
I do not know of any disc brakes, that when you spin the wheel you cant hear the pads at least still touching on the disc... its not dragging , its just a fact that the pads will still touch ever so slightly even when released..
+1
Another thing I was just thinking about is that your wheel may be SLIGHTLY misaligned. Maybe trying to more evenly torque the pinchbolts or discs could help?
However, there's a difference between dragging/binding and touching. If they were dragging bad before, but just barely touching now... you might be ok.
Old Oct 7, 2009 | 09:27 PM
Sprock's Avatar
They'll brush the discs slightly always just never enough to drag the disc to a stop.
Thinking maybe push the pistons in and out a few times either side to free 'em up
a bit ......make everything move easily and as Trout says make sure it's "square"
and aligned
Old Oct 7, 2009 | 11:47 PM
Shadow's Avatar
Ride the bike with the brake on for a mile or two.......................probably stop
Old Oct 8, 2009 | 04:14 AM
oke's Avatar
oke
Check if the caliper pin bolts are binding and doesn´t let the caliber move freely.
Old Oct 8, 2009 | 04:16 AM
hawkwind's Avatar
Thanks for the input guys , it seems to be the right calliper is the culprit , freed the pistons up already and I've been dicking around with the front wheel alignment for ages . The right calliper will stop the wheel from spinning freely , though it will spin , discs are not warped .
Got to go to work this evening , this is the last chance for me to get a re-test , so I'll have to take it down as it is and hope for the best
Thanks again for all the info/suggestions , I'll let you know how it goes
Old Oct 8, 2009 | 06:23 AM
hawkwind's Avatar
Woo Hoo! She passed
What a relief! I would have hated going away without her being sorted out.
Once again thank's for all the input guy's
Old Oct 8, 2009 | 06:33 AM
Dean0's Avatar
For future reference - Caliper piston & seal kits arn't that expensive.
These are the ones I used for my 91 bike
http://www.bitzforbikes.co.uk/Two_Fr...9210-130-.html
and these are the ones for a CBS equipped bike
http://www.bitzforbikes.co.uk/Three_...225-130-0.html
