Bike tuning aid
Old Aug 22, 2008 | 10:27 AM
R1000's Avatar
Default Bike tuning aid
Here is a great instrument whichprovide good helpin tuning the bike. http://www.autometer.com/cat_gaugede...604&sid=11These items are relatively cheap on ebay stores.
The basic principle for tuning a carbed bike is:
1. Adjust the float levels per spec.
2.Select main jets so the A/F ration is about 13 to 1 at wide open throttle under load
3. Adjust the height of the needles so the midrange A/F-ratio is about 13 to 1 under load
4. Adjust the pilot jets so the bike responds nicely from idle and up to a few 1000 rpm's
[IMG]local://upfiles/4562/BC4D49316034474CB9D11CDF34F6638E.jpg[/IMG]
Old Aug 22, 2008 | 11:41 AM
Bassman's Avatar
Default RE: Bike tuning aid
Couldn't find the price or how it hooks up to our bikes.
Old Aug 22, 2008 | 03:56 PM
R1000's Avatar
ORIGINAL: Bassman
Here is one on ebay, there is plenty of them http://cgi.ebay.com/ebaymotors/AUTOM...spagenameZWDVW
The installationappears to bequite simple. You need to weld a M18*1.5 nut on the collector, which willhold the included BoschWide Band O2-sensor. This stud is already in place on later FI-bikes.Then it is just to interconnect the gauge to the O2-sensor (Lambda probe http://en.wikipedia.org/wiki/Oxygen_sensor), plus 12V and ground.
My unit was sent from US this evening, I'll report my findings when it is installed. I guess it will take a week or so for getting it to Sweden.
Old Aug 22, 2008 | 07:16 PM
devildogsc's Avatar
awesome. I am much interested in hearing how it works for you. I know mine is out of tune and needs some adjusting. This instrument sounds like a godsend.
Old Aug 22, 2008 | 08:43 PM
Very cool, keep us posted. I'm sure it will be much more time consuming to tune a carbureted bike than a FI bike. Much easier to change a program than to replace or shim needles, swap out jets, and things such as this. But still worth looking at.
Old Sep 7, 2008 | 03:33 AM
R1000's Avatar
ORIGINAL: idodirt
The meter is in place and works as expected :-)
The O2 sensor (wideband lambda) is screwed into a threaded stud, which is welded to the collector. I thougt it would bedifficult to drill a 20 mm hole in the stainless steel tube, but it was easy with a15 buckHSS conical drill.
[IMG]local://upfiles/4562/FD88C70C408045F3A650FB7C76DFC5F7.jpg[/IMG]
[IMG]local://upfiles/4562/A5B900D6F2854C62A7BDDFB3F27E640B.jpg[/IMG]
Old Sep 7, 2008 | 04:32 PM
Mr Self Destruct's Avatar
Or you can DIY like I do and get this:
http://www.14point7.com/JAW/JAW.htm
Old Sep 8, 2008 | 10:49 AM
R1000's Avatar
Great link, thanks. I may use itin case I need another sensor.
Old Sep 8, 2008 | 11:08 AM
Shadow's Avatar
Hey, R1000, any more gauges and you'll need a pilot's licence for your 'Busa !
Old Sep 8, 2008 | 11:59 AM
R1000's Avatar
Yeah, another license would be fine, just in case ...
