bike has no battery power wont start
#21
#22
RE: bike has no battery power wont start
Had a 1kf that chewed up regulators at a rate of one a month. After mucho head scratching and mucho denero it turned out to be a damaged rotor in the alternator/generator. Not an easy fix, hence why a good mechanic friend fixed it, but hasnt missed a beat since - so i'm told as i sold it to the mechanic who uses it as his daily commuter.
#23
#24
Im going through the troubleshooting guide right now and it says, "Disconnect the blockconnector to the generator closet to the engine. This connect must have atleast three Yellow wires in it or two extra ones."
What is a blockconnector or generator?
Wow Shadow 4 regulators? I'm already at about 200 dollars for 2
#26
#27
I think is was part number 2 from the link below
http://images.powersportsnetwork.com...ALTERNATOR.gif
#28
Im following the charging fault manual and im at
"The fieldwinding in the generator or the brushes to the rotor are at fault. If there are any brushes inside the generator, discconect them and measure the resistance between the two copper sliprings on the rotor. These are the rings on which the brushes run. (If there are no brushes inside the generator, replace the fieldwinding or if thats not possible seperately, replace the whole stator and return to Start.)"
I've taken the cover off of the generator per the Owner's Manual but don't understand what continuity im supposed to test with it off
#29
You need to test the resistance in the field coils - mine was only slightly down, and it cooked the reg/recs.
I had two of my reg/recs exchanged under warranty.
www.electrex.uk - carries a full 12 month warranty !
Very good people.....
#30
ORIGINAL: Shadow1
Am supposed to test the continuity right? I just don't know what field coils, or brushes are.
