All hot and bothered
Old Jul 16, 2014 | 05:52 PM
Conrice's Avatar
Don't those tank bags have straps that run beneath the tank? Maybe it moved and pinched the little hose that comes off of the vent.
Old Jul 16, 2014 | 05:56 PM
wooferdog's Avatar
I will investigate. Thanks
Old Jul 16, 2014 | 06:42 PM
DragonCBR's Avatar
woofer if not mistaken you have a gen one , it haapenned to me when the carbs get too hot i beleive that the gaz in the carbs get evry volatile and the mix is not good anymore, when i get stuck in trafic to long, at one point it behaves as if i was on the end of the reserve even though my thank is full. don't forget, the carbs are right in the way of all the heat of the motor and the motor is fully enclosed..
My two cents
Old Jul 16, 2014 | 06:53 PM
wooferdog's Avatar
My two cents
Dragon, I think you hit the nail on the head.
It acted exactly like I had run out of gas, though I had plenty
Thanks
Old Jul 16, 2014 | 09:04 PM
Sprock's Avatar
Don't duck behind a tree the next time - cool the carbs down instead
I'd check the vac situation with the tank too and the internal petcock screen.
There is a sweet spot in the gas cap where you can drill if the tank vent
is rusted closed or blocked somehow
Old Jul 17, 2014 | 01:28 AM
hawkwind's Avatar
+1 on Dragons suggestion, our bikes get very hot under the tank and seat. Out of interest, did the fuel gauge return to normal when you got her going again?
Old Jul 17, 2014 | 09:42 AM
wooferdog's Avatar
Yes, 'Hawk. It did return to normal.
@ Srock. Cooling the carbs on the side of the road in the method suggested might draw undue attention from the State Patrol. I try to avoid their scrutiny whenever, wherever possible
