Aftermarket exhaust with centerstand?
I've seen pics of a 2nd gen CBR1000 w. a 4-1 pipe on it, and the centerstand in place. My bike has an older VH SS2R pipe and no centerstand (came that way). I assume it's like that because the center stand wouldn't fit, although I haven't tried. Do any of you know of a pipe that will definitely work with the centerstand? I'd go back to OEM, but I'd rather have the 40 pound savings than the slightly improved bottom end.
Thanks!
Thanks!
Ya could have a welding shop "custom" one up for ya..
One of my neighbors is a Welding Guru (In the welding business)
He says ..........it's a snap
My thinking for myself is to get a used Stock Set and have him mod
the end box to a single outlet to suit whatever can I decide to use.
I'm leaning towards a good Arrow or Remus Dual Out Single Can.
The best of both worlds would be to fit a slip-on to the factory system. The trouble you have now is, if the bike is running fine, someone has re-jetted the carbs. If you go with something other than 4-1 you may have to re-jet back to factory.
The factory 4-1-2 gives good top, mid and low end performance. The slip-on takes you to 4-1-1 with the same end results while keeping what's under the bike that you can't see. The 1 in the x-1-x is a collector box that helps mid and low end. You may have been looking at a bike with a slip-on thinking it was a 4-1 set-up.
The V&H systems needed the center stand to be removed for installation. They are an all out performance pipe for racing where high end is needed. V&H made the pipes knowing that the racer would remove the center stand for racing and did not care.
The re-jetting thing may be a pain if you use something other than a pure performance system.
Last edited by TimBucTwo; Jul 31, 2009 at 01:24 PM. Reason: added more high tech stuff.
These would be lighter than factory but you they slip on to the original x-1-x collector.
http://shop.wemoto.com/pictures.dyn?k=MT-XH10L
I've just modded my standard system. Chopped off most of the collector, removed the remaining gauze & then used two 2 1/2" 90 deg mandrel bends to make the rest of the pipe. I then put an old slip on from my 1100 on. This configuration gives me 4-2-1 & I can still use the centre stand as long as I weld the stop for it when it's in the up position.If it does what I hope I'll later take it to Redline Exhaust & have it done properly. Redline told me to use 2 1/4 bends but 2 1/2 were just easier. He also said that he modified a set of stock pipes the same as ours for a racing bike. That year the bike won the superbike championship using the stock headers. By the way. Redline exhaust are here in Adelaide South Australia & he only does bike exhausts.
Thanks!
re: various pipes. Most of that is correct, but the VH SS2 pipe is a street pipe, not a race pipe (the 'SS' stands for 'super street'). Nobody ever raced a 2nd gen CBR1000 (nobody who wanted to win anyway
) and if they did, it was drag racing, not road racing, and that pipe is not a drag racing pipe. The big marketing point of the SS2 pipes when they came out was that they were quiet enough for street use, but still worked well/looked cool. Nobody racing cares how quiet it is.The bike I saw had a full pipe on it, not a slip-on. I'm interested in trying a stand now that the bloke above said that it worked with his...I'll post up and let folks now what happens.
