Adjusting clutch cable
Old Jun 30, 2019 | 04:33 AM
weirdoo's Avatar
Question Adjusting clutch cable
Hello, my bike is a 1993 model, at very specific situations when I have the clutch handle all the way in it still moves and applying the front brake kills the engine and I can't switch to either neutral/2nd gear,I downloaded the workshop manual but I can't find the how-to there. Does anyone have a youtube video about this or a thread? If there is a thread already I apologize for the double post.
PS: I know this is unrelated but maybe important, is it normal for bikes to sway a little while driving?
Old Jun 30, 2019 | 12:27 PM
TimBucTwo's Avatar
Welcome to the forum!
I think you should start by bleeding the slave cylinder.
Its located under the front sprocket cover on the left side of the bike.
Remove the saddle,
Remove the left side-cover,
Remove the left lower faring (use a screwdriver to push the black tang on the black cover that is through the faring by pushing it in towards the cover),
Remove the shift peddle (remember the position it was in),
Remove the sprocket cover.
The slave cylinder is located there.
These bikes don't sway. You may have bad swing arm bearings or head bearings. Are your tires in good shape. Worn out tires will make a bike track poorly.
Old Jun 30, 2019 | 01:05 PM
weirdoo's Avatar
Remove the saddle,
Thank you! There might be something with the clutch system, the internal one, sometimes when I drive I hear a noise coming from under me and can feel something rumbling too. I accidently dropped it when I got it and I'm pretty sure that is to blame. And this happened after the mechanics got it all fixed and ready to go, typical my luck ¬_¬ Gonna give them a call tomorrow
Old Jul 1, 2019 | 05:58 AM
TimBucTwo's Avatar
That noise coming from under could be a dry/tight chain link. When it passes the front sprocket it goes clunk clunk and you will feel it.
Old Jul 1, 2019 | 07:19 AM
weirdoo's Avatar
Is that normal or should I lube it?
Old Jul 1, 2019 | 10:17 PM
wooferdog's Avatar
Chain lube never hurts. Also check chain tension. Too much slack and it'll get clunky, especially when pulling away from stops
Stuck link test. Coast downhill at idle in neutral. If you hear the rhythmic clunking. Time for a new drive
Old Jul 2, 2019 | 08:50 AM
weirdoo's Avatar
Everthing is A-ok!
Shop had a quick glance and the clutch slave cylinder is leaking. They have a parts bike of the same make and year, gonna slap that in tomorrow i believe it was.
Old Jul 3, 2019 | 11:01 AM
TimBucTwo's Avatar
You are one of the luckiest people on the planet.
Old Jul 3, 2019 | 11:13 AM
weirdoo's Avatar
Is it that hard to get spare parts? Including after market?
Old Jul 3, 2019 | 11:19 AM
TimBucTwo's Avatar
On a 26 year old bike, yes.
