88 Hurricane top speed?
Old Jul 4, 2008 | 06:08 PM
Vizionary's Avatar
Default 88 Hurricane top speed?
Does anyone know what the top speed for the 1988 Hurricane 1000 was?
Old Jul 4, 2008 | 06:11 PM
pacojoseph's Avatar
Default RE: 88 Hurricane top speed?
About 155 mph.
Old Jul 4, 2008 | 07:51 PM
DragonCBR's Avatar
top speed as per cycle world for an 88 was 161mph, later years were a bit slower at 155mph.
Old Jul 4, 2008 | 11:50 PM
Honda_Hurricane's Avatar
The 1987 and 1988 had a real top speed (not at the speedo clock) at 258km/h (or 161mph for you who still measures the ancient way) for a good bike. Everything over 240km/h (or 150mph) must be considered as "normal".
If slower you probably have a restricted version and need to do some small work on the intake rubber.
Old Jul 5, 2008 | 12:49 AM
tallenuf's Avatar
My 93 is a California model. What kind of power robbing restrictions/emission controls are on my bike compared to a 49 state or international version. I have noticed a white plastic "restrictor" mounted in the top of my air box, above the filter right where the air leaves the main chamber and goes up to the carbs. Is this thing a CA only piece?
Any guidance on getting back this government stripped horsepower?
Old Jul 5, 2008 | 07:35 AM
Coopz's Avatar
ORIGINAL: pacojoseph
About 155 mph.
Stop using dam imperial measurement, like 2 countires left in the world still using that antique system...
Old Jul 5, 2008 | 05:41 PM
MarkR's Avatar
Metric Rules. . .
Old Jul 5, 2008 | 09:10 PM
pacojoseph's Avatar
ORIGINAL: Coopz
About 155 mph.
Just the important ones. Plus, Vizionary, who originally asked the question, is from the U.S. and presumably was looking for an answer in miles per hour.
Old Jul 5, 2008 | 11:52 PM
Shadow's Avatar
Tallenuf - two things to look for on restrictors :
1 If you can remove the white plate, toss it out.
1 Check the inlet rubbers between carbs and head for a "restrictor ring" - grind them off.
Old Jul 6, 2008 | 02:27 AM
collector's Avatar
In 1989 there was a test done in Germany and the final speed recorded was a whooping 174.09 mph. This was conducted on the autobahn with an independant speed register. Good old imperial.................
