87 honda hurricane 1000, fuel/vac line diagram, & tank cleaning
Old Apr 19, 2014 | 07:48 PM
Chad Brenno's Avatar
the 2 ports indicated attach to some emissions crap on the front towards the front of the bike. or at least thats what the hose routing diagram on my airbox indicates.
Old Nov 2, 2022 | 05:59 AM
Armand Van As's Avatar
Default 750 Hurricane
Originally Posted by Sprock
Well this is a double post but we'll let it slide this time
Your tank is stuffed probably with rust and your carbs - same
Clean carbs, clean fuel pump and filter (or discard pump maybe toast and use a gravity feed with new filter) - seal tank
Hi, regarding this, above mentioned, I got a 750 Hurricane. My carbs are clean and tank is clean, however the bike struggle to reff up. I have set the air but still do the same. I am not using a petrol pump I have check the gravity is high enough so the petrol is flowing strong enough to keep the carbs full of petrol.
Anything I can try else?
Old Nov 2, 2022 | 02:49 PM
dannoxyz's Avatar
Carbs needs complete disassembly to every last nut, bolt and individual component for restoration.
testflyer
Mar 22, 2014 06:59 AM
dougthayer
Apr 5, 2013 12:11 AM
h2opro
Jul 5, 2011 08:51 AM
jam0837
Mar 12, 2011 06:42 AM
rockstar_22
Apr 11, 2010 12:24 AM
