87 - 88 Hurricane USED Aftermarket Exhaust WANTED
Old Feb 18, 2008 | 07:41 PM
Napalm1000's Avatar
Default 87 - 88 Hurricane USED Aftermarket Exhaust WANTED
Cannot afford $400 or so on an older bike upgrade but will possibly pay half.
I really want something that sounds better than a sewing machine running.
Thanks
g4designs@tx.rr.com
Old Feb 18, 2008 | 08:04 PM
MarkR's Avatar
Default RE: 87 - 88 Hurricane USED Aftermarket Exhaust WANTED
Cut the baffle off
Old Feb 19, 2008 | 12:35 AM
CorruptMind's Avatar
ORIGINAL: MarkR
Cut the baffle off
That apply to any of the hurricanes? Also, any rejetting. Would imagine not but I could be wrong.
Old Feb 19, 2008 | 03:20 AM
Daniel_ARG's Avatar
I'm not sure if you can use these... but the might end up being a good deal:
http://cgi.ebay.com/ebaymotors/Honda...spagenameZWDVW
PD: oops, you said aftermarket...! []
Old Feb 19, 2008 | 05:08 AM
Shadow's Avatar
Cut 4" off the can, shorten the baffle by the same amount, reweld/braze/rivet the end plates back, and you'll have a mean set of pipes, jetting should be OK, and the sound is awesome......much deeper tone and a good bit louder, especially past 6000 revs when it has a real snarl......my pipes are s/steel, but are basicly that configuration.......
Old Feb 19, 2008 | 05:53 PM
Napalm1000's Avatar
ORIGINAL: Shadow1
Wish I had those kind of skills! Sounds easy enough if I knew how to start a project like that.
Thanks for all the Replies!
Old Feb 19, 2008 | 05:55 PM
Napalm1000's Avatar
I guess Re jetting for After Market pipes is necessary??
