1990 cbr1000f engine swap issue/question
Old Sep 3, 2012 | 07:10 PM
TheRoachKing's Avatar
Default 1990 cbr1000f engine swap issue/question
I have replaced my 1990 CBR 10000f motor with a 1991 motor and find the new motor dose not have a inlet for the small hose coming from the water pump going to the cylinder head ( the "90" had a nipple between cylinder #1 and #2 but the "91" dose not ). I have no idea what to do with the hose! I have looked all over but don't see were it would go ...any help would be welcome
Last edited by Sprock; Sep 3, 2012 at 08:19 PM. Reason: newcomer needs question in proper section
Old Sep 3, 2012 | 09:18 PM
hawkwind's Avatar
The two motors should be identical, have you taken a look at the parts fiche?
Here's a link :- Fast shipping. Up to 40% off Honda, Yamaha, Kawasaki, Suzuki and Polaris OEM motorcycle parts and accessories. Deep reseller discounts.
Old Sep 3, 2012 | 09:40 PM
Shadow's Avatar
The 89, 90 and 91 engines are identical as Hawk says
Sounds like that 91 engine could be an 88 engine ?
Old Sep 4, 2012 | 11:18 AM
Default hopelessly lost due to incompetence
Well I pulled the engine VIN and ran it at the local shop they said it was a CBR 1000f 1991 engine. I have looked at the microfiche and it was not much help as far as were the line goes. the new engine just dose not seem to have this inlet nipple. I will keep looking for a answer.
Thank you all for your help
Old Sep 4, 2012 | 01:49 PM
CBR1988's Avatar
Senior Member & Lord of the Odometer (300,000 Mles) & Counting
Hey:
Can you take a pic of both and post them on here?
Maybe have a mod help you?
Dub
Old Sep 5, 2012 | 07:50 AM
Default Pic's of old CBR 1000f "90" and "91" water pump and cyl head
Here is a link to some pic's of the new and old engine focusing on the water pump and cylinder head area of the engine
https://www.facebook.com/medi
/set/?set=a.4020202396340.153417.1619826283&type=3
if you can see them I will upload them to this form
Please advise
Old Sep 5, 2012 | 10:47 AM
Sprock's Avatar
Pic link in FB no worky
Old Sep 5, 2012 | 12:27 PM
TimBucTwo's Avatar
^+1
No worky, is quirky!
Old Sep 5, 2012 | 03:42 PM
Default 1990 & 1991 CBR Pictures of Water Pumps
Image of 1990 CBR Water Pump (note nipple). It appears to be exactly the same as the 1991 CBR Water Pump.
View of 1991 CBR 1000 replacement motor. VIN confirms this is a 1991
1990 CBR 1000 motor head--note nipple where waterline from water pump used to attach.
1991 CBR 1000 left side view of cylinder head--note absence of nipple
1991 CBR 1000 right side view cylinder head--still no nipple
Any help in solving this mystery is greatly appreciated!! If anyone has any ideas please let me know.
Old Sep 6, 2012 | 11:40 AM
TimBucTwo's Avatar
That's interesting. The micro fiche shows the same water pump part # for both years. Also, both years have the same head #. There are 2 head #'s listed for both years but they're the same ones.
Don't know why the one head is missing the tube. My '93-'96 shop manual shows both tubes coming off the pump and head but doesn't mention them. It shows the hose connection between them however.
My guess is that its there to bleed off cavitation. I don't think any harm would be done plugging the hose coming off the pump.
or switch heads.
