1990 1000f l Starter clutch problems
Old Nov 14, 2010 | 02:59 PM
mad4bikes70's Avatar
Default 1990 1000f l Starter clutch problems
Hi everyone. I've come for some help Please!!!
My CBR was layed up poorly just over a year ago, with what I was reliably told due to the starter damper (By a mechanic). After parting with £150 at local dealer for new damper (good 2nd hand are like rockinhorse S**#)
I folowed Stu's guide on how to swap it (Thank Mate )
No lost bearings or chains, but same piggy squeal of I don't want to start!!!
Anyone got an idea what to try next...
Stu's Thread posted on this forum
http://www.stu.co.nz/cbr1000fix/
Old Nov 16, 2010 | 10:20 AM
Sprock's Avatar
Able to make a vid so we can hear / see it ??
Old Nov 16, 2010 | 11:18 AM
Indiana Hurricane's Avatar
Senior Member & 2010 ROTY
Question
+1 on the Vid
Old Nov 16, 2010 | 11:36 AM
TimBucTwo's Avatar
Originally Posted by mad4bikes70
..... but same piggy squeal of I don't want to start!!!
Anything like whats in the clip in this thread?
https://cbrforum.com/forum/showthrea...light=starting
Old Nov 17, 2010 | 07:18 AM
Hope this works! Have never uploaded video (Green Newbie )
Heres a link to what I hope is a clip of the sound the bike is making
Sorry about the quality it was done on my phone...
http://www.youtube.com/watch?v=kGB63ibc_C0
Hope that helps!
Old Nov 17, 2010 | 10:07 AM
TimBucTwo's Avatar
I don't hear anything out of the ordinary in the clip. Are you sure you are getting spark and fuel?
Also lift the tank and see if the enrichners are working. With the choke (enrichner) **** engaged, look to see if the slide is moving to the right. These bikes are hard to start if the mixture is not enriched when starting.
With the tank lifted, it would be a good time to check for spark.
The petcock is operated by vacuum and fuel will not flow unless there is vacuum in it. A cracked vacuum line will cause heartache.
Maybe someone else can hear something in the clip but to me it does sound normal.
Old Nov 17, 2010 | 10:35 AM
http://www.youtube.com/watch?v=JOgStqDWsAk
Old Nov 17, 2010 | 10:38 AM
Question
mad4bikes70 your bike sounds like it has a turkey call in there...
Is that the noise you are talking about?
Old Nov 17, 2010 | 10:51 AM
TimBucTwo's Avatar
I don't hear it. Even if it were making that noise the bike sounds like it is cranking fast enough to start.
In the link I posted earlier, that bike in the clip is cranking way to slow to start (defiantly a turkey getting guts ripped out in that clip).
Mine sounds like his clip. Yours sounds cleaner.
Old Nov 17, 2010 | 11:00 AM
Sprock's Avatar
Seems to be cranking normal to me too. No gas I'd say, petcock vac tube maybe !
Weak Battery .....they need to crank 100% to catch and fire !
