1987 CBR 1000F won't start
Hi all. This is my first go at this and I don't really know a lot about bikes. So please bear with me.
I bought a bike off of a friend a few days ago and it hadn't been started for about 6 months. When I went round to collect it, it would not start. He then charged the battery for me and managed to start it up later on. I collected it and started it up the next morning and went to work on it. When I took it out that afternoon it started fine but whilst on the ride I stalled it and tried to start it again and it would not turn over and instead just made a buzzing noise. I then got some blokes to push me down the road to bump start which it did with no real trouble.
When I got home I turned it off and then tried to start it up again but all I heard was the same buzzing noise and no attempt to turn over.
I thought it could be the battery so I put it on charge last night but when I tried it this morning again there was still the same noise.
Any ideas?!
Cheers
Any ideas?!
Cheers
1st off, welcome to the forum!
My guess would be either a bad battery or a bad starter. Some of the more experienced members here will no doubt see your post at some point and maybe be able to give you better info...
Battery sounds like its toast. If you can read the voltage, I'd bet it'll be low especially when trying to crank it.
" So please bear with me. "
And...welcome. I'm sure Bear will be with you shortly. He's traveling right now!
+1 on the dead battery. I had the same problem after a two year layoff. I replaced mine and it hasn't failed me but it would do you well to investigate your charging system to make sure there is no underlying cause for battery failure
good luck to you
good luck to you
+ 1 to all advice so far. Remove the battery and check acid level. Top up with distilled water to the line. Mine was half empty when I got her. You must get a haynes manual so you can do all those great jobs, oil, filters and lubs, while the missus is watching all the cr@p on the tv !! Good Luck - there cannot be much wrong that a battery, fresh fuel and some miles will not cure!
Welcome. Adding to the good comments made already...
You can download free manuals from my link below..
Make sure you download the Owners Manual at least - as this covers day to day maintenance checks. (This manual is for a 1990 model but it will be mostly correct for you mechanically)
Help us help you by filling in your location under personal info - it will then appear in the top right hand corner of your posts.
If you don't know much about electrics then one of these simple testers is a must. They're about $10 and will save you a lot of time & money ( as I don't know where you live I can't give a link to a store but discount auto stores & electrical parts stores have them.)
It will tell you where your problems lie.
eg When connected to the battery with the motor running - if the yellow light at 13.2V is not lit then you have a problem with the charging system. You can then see the solutions in the manual or come back here for more help. We will look out for you.
Thanks everyone. You have made me feel very welcome. I absolutely love the bike and would hope that it is just the battery playing silly buggers as I haven't really got the cash to be forking out for any major works!
I will take the battery out and give it a look. I did charge it today for another 9 or so hours but again the no other noise but the buzzing noise! It just seems strange how it started playing up after I stalled it!
Will definitely have a look at the Haynes manual soon!
And welcome to the forum Spamola!
As all have indicated above battery is most likely the culprit - not enough oomph to spin the starter so the solenoid complains.
Naga's suggestion of a tester is a good thing, and if the battery is your problem it's relatively cheap to fix.
If you replace the battery and still have a problem, most likely it will be an earthing problem so you will need to clean up terminals and earths to the frame.
Let us know how you go!
Cheers, SB
