1000f -89 wont start, help!!
Old 07-16-2009, 05:14 AM
jmmononen81's Avatar
Default 1000f -89 wont start, help!!
so I'm running out of ideas, have changed coils, wires, starter clunch and the other small clunch thats on the charger axel. it gets fuel, air, spark and it turns still nothing somethimes gives a lill promise of starting (max 2seconds) but still nothing! last summer ajusted carburators, it worked just fine and one day after work it didnt started.. PLEASE I really need help!!!!
Old 07-16-2009, 07:42 AM
Sprock's Avatar
Did ya try jumping it from an auto sized battery..........your battery might be done
Run Sea Foam or other such product down the fuel line and see if she'll wake up
with that.
Old 07-16-2009, 10:34 AM
hawkwind's Avatar
Like Sprock says , apparently these bikes need the battery to be 100% , if it's even slightly off the bike wont start , even though all 'vital signs' seem to be OK.
Jump it from a car , but NOT WITH THE CAR RUNNING!! , see if it starts.
Old 07-16-2009, 12:28 PM
Shadow's Avatar
I need more info before venturing any ideas.
Choke cable connected
Is the bike turning over slowly
Is the vacuum hose connected
Is the fuel hose kinked
etc etc
Old 07-16-2009, 09:06 PM
Sprock's Avatar
If it's a starter damper issue then Shadow knows all about that .........
Here's an example of starter damper problems
http://www.youtube.com/watch?v=kfgqjgIeoqk
Old 07-17-2009, 08:00 AM
Default hi!
thanks for quick replys, yes I have tryed start with a car batery(car not running) without result, all hoses are conected, and it gets fuel, yesterday I checked the plugs (again) every one sparks, but with a tiny tiny spark. I suspected the bike batery but still didnt start with car batery..? already renued (new) starter cluntsh and one little clunch on the charger axel where the chain conects from cam shaft(?)
why can't jump start with car running? (havent done it yet, but the temtation is big...heh!)
Old 07-17-2009, 08:14 AM
Sprock's Avatar
Don't jump from car with running ...........too much juice .........y'll fry her ***
Timing issue maybe ?? Valves
Borrow a compression tester start there.......test all 4
Then check timing
Just re read your post..........define tiny spark..........as in hardly any ?
Also as Shadow says ...........CHOKE working right ?
Old 07-17-2009, 08:19 AM
kilgoretrout's Avatar
Administrator - Retired
Sounds like timing to me. Unless the choke isn't connected (like shadow said).
Old 07-17-2009, 08:23 AM
Sprock's Avatar
Must be ESP there Trout man
Old 07-17-2009, 09:55 AM
Yep!
Another thing... are you absolutely sure you have the wires on in the right order? Chit happens, man..
Quick Reply: 1000f -89 wont start, help!!
