Alternative Parts What fits where, what else will fit, resources + bike manuals
Master cylinder to caliper ratio's
Old Jul 19, 2013 | 02:06 AM
Dean0's Avatar
Originally Posted by hillbilly86
Does anyone happen to know the piston size in the stock front master cylinder?
Its written on the side of it. IIRC it's 1/2" ( or 12.7mm )
I did the calculations for caliper/master cylinder piston ratios some time back.
STANDARD master cylinder to STANDARD 2 piston caliper ratio is 15.375:1
STANDARD master cylinder to 3 piston caliper ratio is 23.374:1
CBR600F master cylinder to 3 piston caliper ratio is 14.949:1 ( almost the same as standard )
The CBR600F master cylinder is a 5/8" piston ( or 15.88mm ) and it matches the CBR1000F master cylinder for looks.
CB1300 master cylinder to 3 piston caliper ratio is 19.234:1
The CB1300 master cylinder is a 14mm piston and it matches the CBR1000F master cylinder for looks.
EDIT --- Just been looking at some other master cylinder to caliper ratios :
CBR1000F ( Pre CBS braking system - 2 pot calipers ) 16.00:1
CBR1000F ( CBS linked brakes ) 15.375:1
CBR1000F ( STD master cylinder - 3 pistons linked in caliper ) 23.374:1
CBR1000F ( CBR600F master cylinder - 3 pistons linked in caliper ) 14.949:1
CBR1000F ( CB1300 master cylinder - 3 pistons linked in caliper ) 19.234:1
CBR1100xx ( CBS linked brakes ) 15.701:1
CBR600F ( 4 pot calipers ) 12.69:1
CBR929RR ( 4 pot calipers ) 22.918:1
I was hoping to find a common ratio for linked and a common ratio for non-linked but that is not the case.
Personally I would be fitting the CB1300 master cylinder and linking all 3 pistons in the front calipers
benjy1234
Feb 24, 2014 09:58 PM
IronCityGuy
May 31, 2010 03:56 PM
gt900uk
May 6, 2010 04:36 AM
