Alternative Oil Filter Brands
Guys,
For your info the Ryco Z411 oil filter will fit the 1000F. They are around $12 here in Oz. I got even luckier today and found the Valvoline equivalent oil filter to the Ryco thats 10mm shorter ( same thread size and diameter ) than the Ryco for only $4. I got the last three on the shelf. Its certainly better than paying for genuine ones when these will do the same job for a lot less. I must credit Bluebeard for putting me onto the Ryco info. I'm not sure what the equivalent parts and numbers are in other countries but for Oz this info is the real deal. Cheers.
I go with a NAPA (WIX) upsized filter here in the US Bordo runs about 8 bucks US
The can is way longer but has the same valve psi rating on the inside, make sure
ya check the exact spec's, just because it fits don't always mean it's right for the motor.
Motorcycle-Specific Filters - (About 2.5 to 3 inches long)
- Purolator Motorcycle ML16817 about $6.00
- NAPA Gold 1358, Carquest 85358, WIX 51358 about $7 to $8
- AC Delco PF2135 about $10
- FRAM PH6017A about $7
- Mobil 1 M1-110 about $10
- Bosch 3323 about $5
- Purolator Pure One L14620 about $6
- NAPA Gold 1356, Carquest 85356, WIX 51356 about $6
- Deutsch D-370 about $4
- AC Delco PF-2057 about $6
- Motorcraft Long Life FL-821 about $4
- STP S-02867 about $3
- FRAM, Castrol, Penske 7317 about $3
- Bosch 3300 about $5
- NAPA Gold 1365 about $6
- Purolator L14622 about $5
- AC Delco PF1237 about $6
- STP S-02876 about $3
- FRAM PH6607 about $3
- WalMart SuperTech ST6607 about $2
Technical Fitment Specification 20 X 1.5mm threads, gasket diameter approximately 2.3 inches, O.D. approx. 2.75 inches, length approximately 2.5 to 3.5 inches.
REF: http://www.vfrworld.com/tex_vfr/tech/oilfilter.htm
a part number would be helpful
2.5" - Purolator Pure One PL14612 (yellow one) OR Purolator Regular L14612
3.25" - Purolator Pure One PL14610 (yellow one) OR Purolator Regular L14610
Guys,
Nice write up as usual Naga.
I used to go with the larger filters but went back to the Fram 6017A Motorsports filter because I'm an oil change fanatic and they're readily available at "the store that sells walls"
I've found another oil filter that suits our bikes. I found them on Fleabay and decided to try a couple out. 12 dollars each delivered to the door. Seeing we pay anywhere up to 30 dollars a filter here they are a good deal. This one cross references fine with the 15410-MFJ-D01 which is the Honda part for our bikes.
jharbinson
Aug 15, 2009 09:58 AM
