Aftermarket Discuss aftermarket upgrades to your CBR here.
running lights
Old Oct 4, 2006 | 08:40 PM
raou70's Avatar
Default running lights
whats up everyon?
2005 1000RR, trying to see if anyone knows how to hook up the lockheart flushmounts so that i can have them as running lights when not using the flashing feature. thanks for any advice. be safe and be smart!!!
Old Oct 5, 2006 | 01:03 AM
dragonium25's Avatar
Default RE: running lights
Try using a diode. There are numerous posts about this, just do a search and you should be able to find out how to do it. I read on it a while back but don't remember now.
Old Oct 5, 2006 | 02:49 AM
CBRFREEK's Avatar
I went with the LP Short Stalks to keep runnning lights and end the diode debacle....here is a looksie...
Side View Shorties
Shorties Front
Rear View
Old Oct 6, 2006 | 12:53 AM
Pugetpower's Avatar
I did the same as CBRFREAK (same lights it looks like). With the 3-wire lights, you get the regular "mild intensity" running lights continuously, but the blink filaments give you a "high intensity" flash. For example, it you wire them backwards with the blink lights going continuous, they will start to melt the light housing (believe me I know). Jury rigging a 2-wire system wont give the brighter flash for blink just a soft blinking action.
Old Oct 6, 2006 | 02:36 AM
CBRFREEK's Avatar
I did the same thing...conventional ground idnt not apply here so i wired em up wrong the first time and metlted my plate lamp housing and blew a fuse..so if you use the LP Shorties...read the package closely...LOL...after they are wired in correctly they work WUNDERBAR....
Old Oct 6, 2006 | 03:14 PM
raou70's Avatar
thanks for the info, i will let you all know how it turns out!!!
BlackLion
Jun 27, 2009 02:54 PM
f44life
Feb 3, 2009 08:35 PM
Built B16a
Jun 5, 2007 03:18 AM
malbojah
Jul 13, 2006 12:02 PM
CBRRRF4i
Apr 24, 2006 01:26 AM
