Aftermarket Discuss aftermarket upgrades to your CBR here.
M4 Exhuast
Old May 24, 2006 | 01:13 PM
christhek's Avatar
Default M4 Exhuast
First post, new guy onboard:
I will be installing an M4 slip on (came highly recommended by indysuperbikes) next week on my 02 F4i. Is a power commander with a new map necessary? The bike has a few minor things on it but is factory for performance. Trying to get the most for the least, if possible.
Old May 24, 2006 | 02:00 PM
plasteredbassist's Avatar
Default RE: M4 Exhuast
is it needed? no... will it give you more performance and better throttle response? yes. so its really up to you how much power you want...with a simple slip on your bike will adjust to it fine and you will notice a nice little power increase. if you plan on adding a full exhaust system then a power commander would probably be a wise choice.
Old May 24, 2006 | 02:31 PM
christhek's Avatar
Thanks for the info. I was assuming this was the general answer. I will await to see what others say but so far from others I've heard from, off forum, they agree with you.
Old May 24, 2006 | 03:55 PM
brian's Avatar
Does a powercommander only work for Fi bikes?
Old May 24, 2006 | 06:39 PM
i believe so any older non fi bike would use a jet kit instead which would increase the amount of fuel delivered by the carbs
ORIGINAL: brian
Old Jun 1, 2006 | 07:34 PM
christhek's Avatar
M4 is on and it was super easy. Sounds and looks great too. The power commander was not necessary as it runs smooth but I may do it later to get even more out of it.
Gold
F4i - Wanted
Aug 17, 2014 12:36 AM
BigCat
Nov 10, 2008 01:30 AM
beckspub00
May 8, 2008 05:30 PM
Slow900RR
Nov 14, 2006 10:54 PM
zacl15
Jun 14, 2006 11:08 PM
