Aftermarket Discuss aftermarket upgrades to your CBR here.
LED Rear Pegs
Old Jan 31, 2006 | 10:39 PM
  #21
QuinC's Avatar
Default RE: LED Rear Pegs
ORIGINAL: Tahoe SC
i actually have them on my pegs...they aren't so great during the day as the leds aren't very bright or visible at certain angles.
the strip ones where no drilling is required are super bright from all angles. look into those before you shell out money on these.
T
any links to the strip ones?
Old Jan 31, 2006 | 10:45 PM
  #22
QuinC's Avatar
ORIGINAL: arkas
Cheaper to do it yourself, All you need to do is drill the proper size holes in your peg brackets insert the LED's use a hot glue gun to fill in the back side of the bracket where the wires are located to keep them from falling out, connect the wires ensure you install a resistor so you get the proper blinking speed. If your concern about them being hard to see during the day just give your bracket a quick sand where the LED's stick out and then paint it black, this will make them more visable during daylight hours. I am in the process of doing this myself, I will post pic's when I am finish.
Oh....you can pick up the LED's at any Walmart for dirt cheap (pack of 4-5 for $15) or goto any auto detailer and purchase the more high end LED's, prices will be more expensive for the high end ones of course.
post some pics![sm=bounceybounce.gif]
Old Jan 31, 2006 | 11:43 PM
  #23
scotty8583's Avatar
Yeah, how do the strip ones attach? That sounds interesting!
Old Feb 1, 2006 | 05:31 PM
  #24
Tahoe SC's Avatar
http://www.customdynamics.com/flex_led_array.htm
i believe they have some type of adhesive behind them...they are SUPER DUPER bright even in the daylight AND from all angles.
they stuck on like cement until the PO PO said he need to have his stocks on there as well.
Old Feb 4, 2006 | 12:34 AM
  #25
QuinC's Avatar
ORIGINAL: Tahoe SC
these arent battery powerd are they? i couldn't find any cords..
Old Feb 4, 2006 | 11:45 PM
  #26
Tahoe SC's Avatar
they are like the glow sticks you use at raves. you just crack them...but they last about a month...j/k
hahhahah...no they hook up just like regular lights mang!
BannWorthRulz
Mar 5, 2012 02:49 PM
jagdiver
Jan 13, 2009 08:40 PM
user 3037347
Sep 29, 2008 10:38 PM
brancart1
TRG Coating
Jan 5, 2006 03:26 PM
