900 & + Modifications This section is specifically for questions and advice pertaining to mods of the older models, 900 and up.
cbr900 1996 no recent mods but..
Old Jun 19, 2010 | 06:27 PM
jrzy211's Avatar
Exclamation cbr900 1996 no recent mods but..
Last year i was riding it and was doing about 80mph down a straight away coming upto a stop sign and all of a sudden the bike just bogged out and i tried to get it started and would not start up so i went and got my truck and took it home now since the weather is nice ive pulled it out today and looked at it i get the clicking from the starter sol. under the seat and all the fuses are good so here i was thinking it was my starter so i removed that and grounded while it was removed to see if it would turn over it sure did the starter works and the ign button works lights come on everything but when i installed the starter it wouldnt crank over the engine so i kept the stator cover off to see what was going on internally i could see the starter moving just a little (like just enough to know it works but it seemed like the gears behind the wheel where the stator goes on to is like seized or something)could it be something internal from there that isnt allowing the engine to turn over? i cant even turn the wheel by hand any suggestions and this all happend last year it just bogged out when i was riding i tried giving it gas and it would bogg out faster so any suggestions would be greatly appreciated.
Old Jun 21, 2010 | 07:37 AM
lloydiecbr's Avatar
sound like your oil pump gave up and your engine is seized . or you had no oil in it /or water . what did it say on your temp gauge .
Old Jun 22, 2010 | 02:49 PM
jrzy211's Avatar
Yeah its not the battery had the cover off for the fly wheel took the chain of and had the bike in my bike harness could not spin the flywheel by hand so i put the chain back on and put it in 5th rocked it back and fourth put it back in neutral and still nothing my assumption after reading a lot into this my rings might of melted to the cylinder but ppl have been saying that mystery oil or wd40 of pjb spray and let it soak into the engine a little if its not the rings and something else like a bearing' itll help break it loose but either way its ganna have to be rebuilt bored over over size rings ect any idea on price for this i mean i got another engine that through a rod through the bottom end of the motor so maybe just changing the tops out? and my temp reading for the longest time would go in and out but last time i seen it maybe between 207-212
Old Mar 7, 2013 | 01:28 AM
cam and corona's Avatar
this may sound simple.. did you make sure theres gas in it? tore my bike apart one time.. took the gas tank off and it was as dry as it could be.. haha just sayin.
chromantis
Feb 21, 2013 05:09 AM
scastillo13
Apr 17, 2009 08:18 AM
CBR1000PhoDragon
Feb 26, 2007 05:01 PM
