900 & + Modifications This section is specifically for questions and advice pertaining to mods of the older models, 900 and up.
39mm Keihin FCR carbs on 95' 900 RR
Old Jul 27, 2008 | 12:58 PM
ss6r's Avatar
Default 39mm Keihin FCR carbs on 95' 900 RR
I am in need of jetting information for 39mm keihin FCR flatslide carburetors if any one can help it would be greatly appreciated. I have a 95' CBR900RR with a MVR 4 into 1 full exhaust and a stock motor. I asked SUDCO and they will not sell me or give me any jetting info. These carbs originally came off of a Yamaha and the jetting was way off for the 900rr. Changes have been made to them so far but still can't get them right, when you roll on the throttle it picks up good and goes, but when you hammer the throttle the bike boggs and hesitates before smoothing out and accelerating hard. Thanks
Old Oct 18, 2008 | 08:19 PM
csjray's Avatar
Default RE: 39mm Keihin FCR carbs on 95' 900 RR
My setup is pretty similiar to yours. I run a #120 jet but it could use a little more. Also having them synchronized would help alot
Old Jan 11, 2009 | 04:55 PM
epp.racing's Avatar
I am building a pulling tractor with a 95 900rr engine. I was wondering what air filters and what are you getting these carbs off of?
Old Jun 19, 2009 | 09:01 AM
bigpipe's Avatar
Default 39mm Keihin FCR carbs on 95 900 RR
I have a quick question about boring a 41mm FCR. Do you bore the 41mm carbs? and how large can you bore it to? I am looking at maybe boring it out when I bore my bike to a 500cc later this summer.Thanks, Rob Deimn guys! Black eyed peas - Boom boom pow has blowed my brain ))) try it and write me PM your mind)
Old Jul 3, 2009 | 05:18 PM
jason600's Avatar
with those carbs u can never just crack the throttle it will always bog
Old Sep 9, 2009 | 07:03 PM
dylanr's Avatar
Default fcr carbs
i have a 600f3 with the fcr carbs and i have the same problem. if i roll on the throttle it runs great but if i crack the throttle open it bogs.
jackojeff
Jul 11, 2013 11:10 AM
ryano900rr
Nov 18, 2009 08:40 PM
ducatijay
Jan 9, 2008 06:42 PM
