600 Modifications This section is specifically for questions and advice pertaining to mods of the older 600 models.
universal gear indicator on F2
Old Jul 28, 2011 | 03:37 PM
Daniell's Avatar
Question universal gear indicator on F2
anybody who hav installed this sucsessfull?
Blue Universal Digital Gear Indicator for Motorcycle | eBay
i have this on my own F2, but cannot get the neutral to light 0 when shifting 1 up to 6 and down again.
will only show 0 when i turn on ignition..
Daniell
Old Aug 1, 2011 | 02:06 PM
jveach's Avatar
was that hard to install? I'd like to have one on my F4i, I'm always forgetting what gear I am in.
Old Aug 1, 2011 | 02:19 PM
this guy's Avatar
R.P.M's tell you what gear you are in
Old Aug 2, 2011 | 02:21 AM
Daniell's Avatar
not really hard to install.
BUT, the magnetic are sensitive, so its easy to overshift so the indicator doesn`t hang with, so when the indicator shows 4th gear you are in 5th or 3rd gear.. maybe its only to adjust the sensors a bit.
Old Sep 6, 2011 | 04:04 AM
arekczyzo's Avatar
Daniell
Daniell, have You installed that indicator correctly?
I mount it on my VFR and I have same problem as You.
Old Sep 7, 2011 | 12:49 AM
arekczyzo's Avatar
Talking
Hello again,
I solved that problem with our universal gear indicator.
In my VFR 800FI `98 there is a module called "clutch diode", and that diode send signal to the NEUTRAL INDICATOR.
bez tytułu II.JPG - Rozmiar oryginalny - Fotosik.pl
And that diode causes problems with our Universal gear indicator.
In my vfr I took the WHITE cable from our gear indicator and connect with the cable from "neutral switch" before "clutch diode". After that, our problem with the indicator disapeared AND IT WORKS CORRECTLY.
I can not find wiring diagram for CBR F2, but I found the diagram for CBR F4, and I saw the "clutch diode" on that diagram, that`s why I think You could have same problem as I.
Ride to live...
Old Sep 7, 2011 | 08:31 AM
Daniell's Avatar
i did follow the instructions.. so i guess i did it correct..
Old Sep 7, 2011 | 08:33 AM
Daniell's Avatar
Hello again,
bez*tytułu II.JPG - Rozmiar oryginalny - Fotosik.pl
Ride to live...
supert
i will try to find a diode.
do you have the problem that it will show up tp 8th gear?
do you have a picture of yours mounted?
Old Sep 8, 2011 | 07:25 AM
arekczyzo's Avatar
Hi, i do not have pictures yet, because at the same time I decided to change - in GIMP - my speedometer from miles to kilomteres. And I did not complete my bike yet.
I will show You pictures. I promise.
I do not understand problem with 8 th gear?
It will always show You 7th or 8th gear if You make bad shift.
It will correct counting after going down to the neutral.
Old Sep 9, 2011 | 08:30 AM
Daniell's Avatar
about 7th and 8th gear, what you said makes sense.
then i will wait for a picture from you
Daniell
