600 Modifications This section is specifically for questions and advice pertaining to mods of the older 600 models.
Question about rr tail conversion
Old Apr 22, 2010 | 10:22 PM
TooBroke0029's Avatar
Default Question about rr tail conversion
im having issues with the seat alignment it seems like the seat sits way to high on the tank or way to low. does anyone have any pics they took whil htey did the conversion ? t
this is what ive got so far and im kinda of confused i feel the seat should sit up higher but than there a pretty large gap under the seat. any help would be appreciated
Old Apr 23, 2010 | 06:37 PM
Turbulenz's Avatar
Official Welcome Crew
It would probably help if people knew what kind of bike you had.......
Old Apr 23, 2010 | 10:35 PM
Oops! my bad its a f2, i sliced off most of the stock mounting locations and also where the tail light mounts to the back. i figured if i need it back on i can always weld it.
Old Apr 27, 2010 | 04:25 AM
turbotransam83's Avatar
What year RR tail are you going with? I used the 03-04 tail. this is how mine sits.
All i did was make a bracket to go from side to side so the seat can hook into the front. The back bracket is purely for support. I have the tail mounted to a stock 600rr latch which holds the rear of the fairing tight.
I bent 2 brackets into an L shape and mounted them to the stock subframe and bolted the 600rr passenger/solo cowl latch to it.
Attached Thumbnails Question about rr tail conversion-img00060-20100420-1620.jpg   Question about rr tail conversion-2563558_n.jpg   Question about rr tail conversion-p4040201.jpg
Old Apr 28, 2010 | 01:01 PM
The tail is from an 05, i decided to just go to own with 1/2 and 3/4 swuare tubing. its all tacked in place right now but it would have been a hell lot easier to make brackets. do i need the trunk compartment for the latch ?
Old Apr 28, 2010 | 11:42 PM
lots of welding but its all secure i plan on making a "trunk" space out of fiberglass in the rear and using that as the undertail section. i still need to remount the battery box after some trimming. anywhere i can get the rear seat cheap?? thanks a ton ill have my bike out for the first time on sunday if all goes well.
Old May 11, 2010 | 03:54 PM
bammerman's Avatar
Turbo did you have to bend your subframe at all?
Old May 11, 2010 | 08:12 PM
Im going to when i get the rear seat mount in. Then im going to make a custom undertail. some people cut the tail im going totry to bend it.
Old Aug 21, 2022 | 02:10 PM
Maverick446's Avatar
Default Hey
Hey which front fariign are u using?
goatxxmastr
May 30, 2021 08:24 PM
removebeforeflight
May 21, 2012 10:37 AM
Aukai
Mar 17, 2010 03:32 AM
ride_002000
Apr 3, 2007 01:54 AM
Faerl
Oct 14, 2005 11:34 PM
