600 Modifications This section is specifically for questions and advice pertaining to mods of the older 600 models.
igntion advance key
Old Jul 7, 2007 | 11:55 AM
gag1938's Avatar
Default igntion advance key
Does anyone run an advance key on a 600f. I wanted to get one but when I looked at mine the other day I noticed it was gold colered ( zinc plated ) I think it might be aftermarket already but I couldn't see any markings. Does anyone know if the stock key is that color. Also, did the advancer make any difference?
Old Jul 12, 2007 | 10:47 PM
dementedf3's Avatar
Default RE: igntion advance key
Uh do what????????????
Old Jul 13, 2007 | 08:47 AM
gag1938's Avatar
Sorry I will clarify. If you remove the igniton cover you can see the trigger/key. It is common to upgrade to a key which has a different setting to creat advance usually around 4 degrees. Check out this auction number on ebay
290138875056
So I had my cover off and my key is the same color as the one in this auction. I was thinking the factory one might be a different color like gear that connects to the starter. If so then I know I don't need to shop for one.
My friend installed one on his GSXR and said it had a little nicer throttle response. I was hoping someone had installed one on their F1 and could give me some feedback.
hope this clears things up.
Old Jul 23, 2007 | 12:08 AM
blkpitbull's Avatar
The stock "rotor" should be a grayish color. If your is a "golden" color yours is probably aftermarket!
zoniebutt
Feb 25, 2008 11:03 AM
Indiana929
Dec 17, 2007 03:39 PM
Indiana929
Nov 2, 2007 08:28 PM
camoweasel
Sep 24, 2007 08:48 PM
gag1938
Jul 7, 2007 05:21 PM
