600 Modifications This section is specifically for questions and advice pertaining to mods of the older 600 models.
F3 to rr tail
Old Jan 18, 2011 | 09:44 PM
ZachLeon's Avatar
Default F3 to rr tail
I know that this is probably asked all the time, but I couldn't find a thread relating to it. I just want to know how the rr tail would fit on a 95 F3. I love the rr tail. Would it be any easy install, or would I have to totally slaughter the current frame?
Old Feb 1, 2011 | 04:46 PM
VALKYIE's Avatar
It can be done just depends on what way you go about doing it. The easiest way to do it is by heating up your subframe and bending it up a little. That way the subframe ends are not sticking out the back of the RR fairing. Then heat them up and bend them back down when you want to go beck the the F3. The same with the seat mounting holes heat them up and beat them down.
To mount the RR seat make a mounting plate the fits the holes for the RR seat then either weld it to the F3 frame or install it with nuts and bolts by drilling mounting holes into the subframe. Make sure its in the proper position.
cds83
Jul 3, 2013 12:05 AM
