600 Modifications This section is specifically for questions and advice pertaining to mods of the older 600 models.
F3 Engine in a F2 Frame
Old Jun 8, 2016 | 11:54 AM
fatso1277's Avatar
Default F3 Engine in a F2 Frame
Okay I finally gotta hold of a F3 engine. So decided its time to go ahead and start putting this thing back together. Now I am reading conflicting things. My goal is to use the F3 engine with the F2 carbs. My understanding is that I will need F3 harness and ecm. I read somewhere else that the F2 and F3 harnesses are he same as well as ecm. I still plan to use the speedo for the F2. Can anyone provide some info on what I need to actually do here. I would greatly appreciate it.
Old Jun 8, 2016 | 11:17 PM
coalminer frank's Avatar
The F3 wire harness has the throttle positions sensor that goes to the carbs, where as the F2 does not. And the F3 has a little different ignition timing or cam timing. Get yourself a F2 manual and F3 manual and compare the timing issue. I would think that if they were the same or very close, that it wouldnt make that much, if any difference. I would think the F2 harness would work on F3 engine w/ F2 carbs.
Old Jun 28, 2016 | 09:46 PM
I was reading some old posts and found someone here who said F3 engine will run just fine on F2 harness & F2 ECM and F2 carbs. He said "been there, done that". The only difference with the F3 ECM is there are additional plugs for the TPS which the F2 doesnt have.
estate4life
Nov 29, 2013 07:02 PM
captain crash
May 17, 2010 06:30 PM
tank_900rr
Apr 30, 2007 12:42 AM
