600 Modifications This section is specifically for questions and advice pertaining to mods of the older 600 models.
CBR600F4 rear subframe swap to 2006 1000rr subframe
Old Aug 19, 2023 | 08:25 PM
FatApe79's Avatar
Default CBR600F4 rear subframe swap to 2006 1000rr subframe
I want to swap my 2000
My bike currently. The back half of the seat is chopped off.
CBR600f4 rear subframe and seat to the 2006 1000rr subframe and seat. Does anyone know if the subframe is compatible or what the dimensions of the 1000rr rear sub frame is? I know I need the rear subframe, two seats, and the underframe battery tray thing and possible the rear fairing. Does this sound somewhat feasible?
Old Aug 19, 2023 | 11:38 PM
dannoxyz's Avatar
Why 2006 CBR1000RR?
What measurable benefits is there?
Old Oct 6, 2023 | 10:41 PM
Muga's Avatar
It is harder to do it with the 2006 subframe because of the way how the f4 tank is mounted on a piece of iron on the f4 original subframe and 06 1000rr doesnt have that piece and its al a weird angle also. Plus the mounting holes to the frame is alot different but if you could fab a bracket that could work. Let us know what you get though.
Old Oct 7, 2023 | 09:02 AM
rockpool's Avatar
Anything is possible given a drill, a saw, and a can of spray foam.
What look are you trying to achieve? you already have a ratted out CBR600?
Old Aug 27, 2025 | 09:16 PM
Wguthrie721's Avatar
Default Looking to swap motor and swing arm on to new frame
Just womdering if you can pull motor and leave swing arm attacthed to roll under new frame and front end
Old Aug 28, 2025 | 07:03 PM
rockpool's Avatar
Go look at the bike - look where the swingarm is attached, then you will know the answer.
Conrice
Apr 30, 2014 06:15 PM
msbeard
Jan 27, 2006 09:42 PM
95rr900
Jul 23, 2005 01:12 PM
