600 Modifications This section is specifically for questions and advice pertaining to mods of the older 600 models.
'06 600rr rim on F2
Old Jun 27, 2007 | 12:00 AM
FNQuickF2's Avatar
Default '06 600rr rim on F2
Exactly what the title reads..Will it fit?...got a bead on one with disc too..
Thanks,
RB
Old Jul 5, 2007 | 10:31 AM
ajlong's Avatar
Default RE: '06 600rr rim on F2
I don't think it'll fit properly. From my experience of changing out my swing arm to an 04 600rr on my F4, you have to make sure your chain lines up perfectly, and by increasing the size of the rim/tire, you probably wouldn't be able to keep your tire true to the frame, it'll probably be pushed to the right and not line up properly. Don't know if a swing arm change would be required, but can't see that helping either. You'd need to find a way to shim your front sprocket in order to get everything to line up. Plus, the RR's use bigger axels than the F series.
jjoube84
Aug 5, 2014 06:46 PM
CBRf4iX
Apr 8, 2013 12:39 AM
unit21
Jan 21, 2008 08:31 PM
