what else can i do to my 05 600rr?
Old Jul 10, 2007 | 02:53 PM
c45's Avatar
c45
Default what else can i do to my 05 600rr?
hey guys, i have a 05 600rr, i have a power commander, K&N filter, and leo vince slip on, what other mods can i do to get more power? i would like to get them done before i take it in for the dyno tune. thanks.
Old Jul 12, 2007 | 11:48 PM
tomp's Avatar
Default RE: what else can i do to my 05 600rr?
get a full system, pairing vavle mod
Old Jul 13, 2007 | 06:38 AM
c45's Avatar
c45
thanks i'll look in to it
Old Jul 13, 2007 | 07:42 AM
baxsom's Avatar
pair valve will not do anything at all for power
all it does is inject air into the exhaust to burn the unburned fuel
there are only two reasons to block it
to get a custom map done because it will inject air and ruin the air/fuel reading,
it weighs almost 1 lbs
now besides the full system a custom map
look up velocity stack mod (basically taking two sets of velocity stacks, cutting them in half and only using the short ones but it will require the custom map)
you can also use more of the power you already have by reducing rotating mass
take off as much weight as possible off of the rear whee,
520 conversion with AL sprockets, titanium rotor bolts, sprocket studs and sprocket nuts
BST wheels
less hp to turn the wheel is more hp on the ground
Old Jul 19, 2007 | 05:18 PM
cbrman3786's Avatar
i agree, get full exhaust first
jjoube84
Aug 5, 2014 06:46 PM
CBRf4iX
Apr 8, 2013 12:39 AM
unit21
Jan 21, 2008 08:31 PM
