undertail ? cant get blinking to work
hey, i just bought the ss kit and undertail kit from bikelitez and cant get it to flash. i bought some flush mounts about a month or so and put them on and the lights say on and they flash. i tried to hook up the undertail lights and got them to work but they wont flash and they also stay on too. i tried hooking up the resistors that he gave me with the kit and that still didnt do any thing. any help would be awsome.
thanks
thanks
ORIGINAL: dragonium25
Did you hook up the resistors properly? In parallel?
If you have LED turn signals in the front and back, then you'll need to put resistors on either the front or back set to slow the blinking rate. I have an integrated tail light and front flush mounts and needed to put resistors on the front.
Are you sure your tail light is connected properly? It should only be a connector piece that hooks up to the existing stock connector. Then you splice the left and right turn signals.
in the pics it shows how i have the wires hooked up and what the brake light looks like, when i turn on the turn signal, it blinks red, so i think i might have something backwards but i tried everything and so did the guy from bikelitez. i ask if they was any way to not use the resistors and he told me that i have to have them. any help would be great.
if you think i should switch some wires or something, plez post the picture and write in the picture so i know exactly what you are trying to say
thanks alot for the help
