Turn signal issue
So i am having an issue with the turn signal on my gauge. All signals on the bike work correctly but on the gauge itself the right one does not blink. The left one works perfect. I just had the gauges done from scott at bluegauegs and i had him test the gauge itself and he said everything was fine. So it has to be the wiring leading up to the multi connector or something of the emain gauge.
Again its not the blinkers on the bike those all work front and back. It is the right blinker only on the gauge itself that is not working. (i hate turning and leaning over the side of the bike to see if i have my right blinker off or not) Where do i start and how do i diagnose where the short or problem is. I am an electrical idiot and have no clue where to start. please help |
I would start by taking it back to "whoever" did it and say, its not alright, my right side signal dont work now and demand they fix it. If I paid them already, this is what I would do. Probably the little bulb in the gauge.
Most likely its the bulb inside the cluster. I would take the cluster apart and check that first, otherwise check the wires .
it is not the gauge i am 100 percent. I bought this bike like this and i have seen it flicker on once in a while. Must be a loose wire maby. I then just got my gauge done and him make sure it is not the gauge. He said he tested the gauge and its not a bulb or anything so it has to be a wire on my end. Where would i start to do this and does anyone know what wire i am looking for. I believe it is solid green and orange are the turn signals. Where would i start guys
Thanks |
