Removing the reflectors
Old Jun 17, 2007 | 02:17 PM
Drekkyk's Avatar
Default Removing the reflectors
I removed the reflectors on the front wheel on my 07 600RR, and when I put the screws back in the fender, the rubber grommet gets squished from around the screw. I'm wondering if we need to keep the reflector bracket in there to provide the proper spacing for the front fender?
Drekkyk
Old Jun 17, 2007 | 03:30 PM
james007torres24's Avatar
Default RE: Removing the reflectors
y not just use a washer or something?
Old Jun 17, 2007 | 05:58 PM
Drekkyk's Avatar
I dunno, I thought the rubber is supposed to be there. I was just curious what others have done, if anything.
Old Jun 19, 2007 | 08:35 AM
bigcha40's Avatar
cut the reflector off of the bracket and then put the bracket back where it was thats what i did and all turned out well. i cant remember if i flipped the brackets around so the cut part would not be visible but give it a try i think you will like it.
Old Jun 19, 2007 | 12:08 PM
Drekkyk's Avatar
Yeah, I think that is what I'm going to do. Thanks for your post!
Drekkyk
Old Jun 19, 2007 | 06:12 PM
2006f4ido's Avatar
+1 ^^^^ take reflector off....and put it in a vise and hacksaw (or dremmel)it off so it NOT exposed around your fender...then reinstall using new custom mod.....
Old Jun 19, 2007 | 06:30 PM
Jared's Avatar
I just bent mine repeatably until it broke the so the rest of the bracket wasnt there.
Old Jun 20, 2007 | 12:43 AM
Drekkyk's Avatar
I finished it tonight! I held it with vice grips and then hacksawed with other hand. I honestly dont know of a harder way to do it, but I did it that way anyway LOL. Much better fit. Thanks!
Old Jun 20, 2007 | 04:51 AM
Ludefreak's Avatar
i was wondering about that i had the same problem,, thanxs for the info..
Jukitsu
F4i - Wanted
Jul 22, 2014 04:58 PM
01f4iGuy
Mar 9, 2007 09:30 AM
ddaren
Feb 27, 2007 09:36 PM
gottabfordtough
Dec 23, 2006 07:18 PM
killersworld
Jun 5, 2005 07:57 PM
