position light??
Old Jan 11, 2006 | 05:10 PM
BlindinOrange's Avatar
Default position light??
I think its called the position light..... anyway its the light thats directly over the headlamps. what type and size bulbs are they??
Old Jan 11, 2006 | 10:42 PM
doncollins's Avatar
Retired Administrator
Default RE: position light??
I've always called it the front marker light... it's a 12V5W and it's a 194 bulb. I ordered the LED194W so it's not the yellowish look.
Old Jan 11, 2006 | 11:05 PM
chainstretcher's Avatar
Admin Emeritus & MVN
Yo Don, where'd ya get that light at? I found 'em on e-bay a while back but can't find 'em now. Sux for me to have the pretty blue HID's and the yeller position light.
Old Jan 11, 2006 | 11:36 PM
doncollins's Avatar
This is the same guy I ordered from.
Old Jan 12, 2006 | 10:18 AM
josho66's Avatar
How is the install of the bulb. I have never even looked, probably easy, just thought I woudl ask though
Old Jan 12, 2006 | 04:13 PM
doncollins's Avatar
Simple... two screws on the front then find something that you can hook in behind the plastic lens to remove it. Mine was a little difficult so I used a paper clip to hook in the screw holes and pull it out. The bulb is a simple plug in.
Old Jan 12, 2006 | 10:58 PM
josho66's Avatar
ORIGINAL: doncollins
Thansk. I will have to give one a try.
Old Aug 5, 2007 | 10:28 PM
highflyin128's Avatar
What is the position light for? Or is it just a marker
Old Aug 5, 2007 | 11:39 PM
Blue Fox's Avatar
Retired Moderator
ORIGINAL: highflyin128
It's actually more of a "sidemarker" type of light. If you have your lowbeam on only at night, and you look at the right side of the bike from a distance, you can not tell the headlight is on. But you can see the "position light" serving as a "sidemarker" type of light.
It's a 194 wedge-base bulb and you can get LED's for this light at http://www.superbrightleds.com. This is where I buy all my LED stuff from, and they're great.
Old Aug 6, 2007 | 02:13 AM
thecannibalchef's Avatar
i believe you can actually just remove the bulb socket from the back of the housing with 1/4 turn to the socket, rather than remove/damage the lens and mess up that foam gasket. those bulbs tend to come in pairs - does anybody have a spare?
