No Muffler.. Bad?
Old Jun 25, 2007 | 08:40 PM
1BadCBR07's Avatar
Default No Muffler.. Bad?
Pulling the factory off...
Putting FE kit on...
And attaching just a small side pipe to dump exhaust (no muffler)..
What are the effects of this.. I've searched and searched with no real answers.. Help me out here guys...
Thanks
DH
Old Jun 26, 2007 | 03:04 PM
urandaman's Avatar
Default RE: No Muffler.. Bad?
not sure how it will affect the bike, but on my last truck i ran no muffler instead of putting aftermarket on and it lost low end power....
and it will be ridiculously loud!
Old Jun 26, 2007 | 03:42 PM
jutsin's Avatar
Police and your neighbors will hate you.
Old Jun 26, 2007 | 04:11 PM
nfamousdevil's Avatar
depending on how far away from the head your "dump" is, it's a possibility that you might burn some valves. but as long as you keep it reasonable (i.e. after the header) you should be fine. And everyone above is correct.... your neighbors will hate you because it will be rediculously loud. Oh yeah, watch out for that "popping" with all that unburnt fuel.
Old Jun 26, 2007 | 04:27 PM
Triax's Avatar
He's correct you will burn your valves up and loose horsepower. The engine needs a certain amount of backpressure to work and preform properly. So I would suggest dealing the factory pipe until you can afford a slip on exhaust.
Old Jun 27, 2007 | 09:21 AM
Blue Fox's Avatar
Retired Moderator
ORIGINAL: Triax
+1. EXACTLY! (and +1 to the neighbors hating you too.)
Not to mention, you just voided your warranty entirely.
Old Jun 27, 2007 | 07:38 PM
baxsom's Avatar
ORIGINAL: Blue Fox
ORIGINAL: Triax
you void the warranty as soon as you put an aftermarket exhaust or pc3 on the bike, or disable the PAIR.
Old Jun 28, 2007 | 07:15 AM
Blue Fox's Avatar
Retired Moderator
ORIGINAL: baxsom
The very reason why I haven't done any of the said modifications.
Old Jun 28, 2007 | 11:05 AM
OZ.CBR600RR's Avatar
Have a look at this. All I can say is.Who Cares about the power Etc. It shounds like ****. run a good muffler on it. PLEASE.
https://cbrforum.com/m_327778/tm.htm
Old Jun 29, 2007 | 11:59 AM
06cbr600rrguy's Avatar
WHAT IS A SPEEDO HEALER?
WHERE U GET ONE... WHAT IS GOOD REASON FOR HAVING ONE?
is there a resonalble worth it difference for a 520 chainconversion verses stock?
Thanks
