Mesh, Watsen turn signals, & FE fix
I finally got around to doing the meshing on my fairings and here they are. It was a lot easier than I thought. Just got some aluminum mesh from Home Depot that they use for stove overhead fan filters. Cut them to shape with scissors and mounted them to my fairings with a hot glue gun, and then used epoxy to ensure they would stay on and resist any heat.
http://www.imagestation.com/4599018/3962761451
http://www.imagestation.com/4599018/3962761446
http://www.imagestation.com/4599018/3962761433
I also got my Watsen turn signals which look super-tricked out http://www.watsendesign.com
They were simple bolt-ons and I had to use the resistors provided so that they'd actually blink and not just look like they were on the whole time.
http://www.imagestation.com/4599018/3962761130
http://www.imagestation.com/4599018/3962761070
http://www.imagestation.com/4599018/3962760890
http://www.imagestation.com/4599018/3962760862
http://www.imagestation.com/4599018/3962760853
And finally I fixed my plate light so it shines directly onto my plate. I had bolt lights before that came out of the plate and shined forward. I had to use these metal tabs to reflect the light downwards. To fix the problem, I made a little metal tab and bolted onto my reflector bracket. Then I used the same bolt light and mounted it onto the homemade tab.
http://www.imagestation.com/4599018/3962761357
http://www.imagestation.com/4599018/3962761253
http://www.imagestation.com/4599018/3962761176
So this is what my bike looks like thus far:
http://www.imagestation.com/4599018/3962760871
http://www.imagestation.com/4599018/3962760633
Hahaha, ya like that huh? I needed something to cover my floor so I wouldn't scratch them, or my fairings, while I did the install and that was the first thing I found.
I dont know, you need some safety on the side, especially on a black bike, and for sure at night. I may look cleaner, but I likethe idea of them being there (maybe a different color possibly)
ORIGINAL: D2MEclipseGT_600RR
