Just installed my Protons
Old Jun 2, 2006 | 10:26 PM
BrianAZ's Avatar
Default Just installed my Protons
Well, I just got a set of Protons for my '06 F4i. For anyone considering these, here are some thoughts:
One of the signals wouldn't seat properly. I examined it against the one that fit fine, and it appeared as though it bulged a bit at the bottom. In order to make it look right when I tightened the nut, I had to put a makeshift spacer between the light and the plastic cowl.
The threaded shaft used to secure the light to the bike was not put into the light correctly. When I attempted to tighten the nut, the shaft turned and began to drill deeper into the light. I had to epoxy the shaft into the light assembly so I could tighten the nut.
The lights are marketed as having built in regulators to avoid the "fast flash" problem. I followed the directions exactly, but my signals still flash faster than factory. Changing the wiring between the orange and yellow on the light didn't make any difference. On the bright side, I was able to get the running lights to work as well as the turn signal.
Uninstalling and re-installing all the plastics on the bike isn't hard. However, if you are doing it alone, and it is 117 degrees in your garage at the time, it really sucks.
All in all, I probably would have been happier with the Greggs.
Old Jun 4, 2006 | 05:10 AM
liquid_iq's Avatar
Default RE: Just installed my Protons
[sm=ttiwwp.gif]
Old Jun 4, 2006 | 05:48 AM
tmut121's Avatar
haha! word....
Old Jun 7, 2006 | 02:45 AM
hotwire's Avatar
i put the proton lts on a couple weeks ago and i love them!!!! i had no problems with the lights or the install.i would say that if you bought them ****ed up send em back
Old Jun 16, 2006 | 02:50 PM
BrianAZ's Avatar
Sorry for the crappy pics. I didn't have a chance to take any pics during good light.
Old Jun 19, 2006 | 10:45 PM
jorge13's Avatar
What type of bar ends do you have mounted ?
By the way I love your colour combo !
Cheers
Old Jun 19, 2006 | 11:58 PM
kiggy74's Avatar
I had a similar experience installing the Protons on my F4i (before I sold the bike). Especially on just one side, it seemed like the wires coming out of the back side of the light didn't fit the hole in the fairing right, so I ended up drilling out the hole just a little so they'd fit better.
As for the flashing issue, did you happen to do the tailight too?
Old Jun 20, 2006 | 12:01 AM
BrianAZ's Avatar
ORIGINAL: jorge13
Cheers
HVMP small weighted bar ends. Helps greatly with vibrations.
Thanks for the compliments.
Old Jun 20, 2006 | 12:03 AM
BrianAZ's Avatar
ORIGINAL: kiggy74
Tailight is stock. Rear turn signals are bulb, not LED.
Old Jun 26, 2006 | 11:39 PM
FastCRX's Avatar
wow sounds like i should stay away from them. I just got my 06 F4I (yellow/graph gray) where have you been finding all your parts? i look on ebay and google the **** outta 2006 CBR 600 f4i.
