jardine dual outlet V 2 bros M-2
Ok '07, I got a little crazy and started ripping apart things only to realize I'm not going to have it put back together right away. [&:]When are you looking to make your buy?
what are you going to be doing to it?
not for a lil while yet prob just after the new year gota save up some money plus im still trying to decide what pipe i want to get haha
ORIGINAL: 07white600rr
Guest
Posts: n/a
ORIGINAL: D2VW14_20
That you and your dad and his RVT??? Bike sounds good man, where was that at?
Thanks '07,
G2-R Gold Valve Kit for the Front along with FRSP S3627090 .90 kg/mm springs. Can't afford the cartridges yet so I figured i'd do this to tie me over for awhile.
In terms of power, nothing. With just the suspension upgrades I should feel more feedback/response under heavy braking and hard cornering. If I get the rims/rotors that will reduce down onthe rotating mass allowing the bike to accelerate easier and stop with less effort (Not as much momentum(sp) going into the corners. Probably the best upgrade you can do for a bike.
ill have too keep that in mind for when i start to upgrade my bike. good luck with everything.
got that sound clip sense u shortend you pipe btw?
