how to pollish motorcycle parts??
RE: how to pollish motorcycle parts??
a 600rr would be easy it has a whole frame unlike my 954rr, i dont think you have any part of your subframe showin cuz i think the plastic shields cover it up. the swing arm is not covered by a exhaust, so it should be real easy compaired to what i did.
i stay in texas home of humid air, if mine gets wet i just run one coat of polish back on it and it comes back to life. yes you can clear cloat it but when clear coating it you have to take all the greasy film off(polish) so the end product will be real dull, it actually wont look chrome what so ever. just gotta relize before you start polishin the bike that yes it has a lil more upkeep than the factory finish, but it can turn a bike upside down.
Heres the best way to start. Screw sanding with 220 grit (like rocks on paper...) Get a can of "Aircraft aluminum stripper" It will pull paint or clearcoat right off the aluminum; then start to wet sand & polish from there. I would suggest that after you have polished your parts/frame/wheels, get them clearcoated. This will prevent oxidtion and make it so you don't have to spend countless hours polishing when it starts to oxidize...[:@]
ORIGINAL: shanelemus
Yes, when clearcoating the wax/polish/whatever must be removed for the clear to stick. What you don't understand is it isn't the polish that makes the metal shiny. It's the fact that the polish has smoothed out the surface of the metal. The metal stays smooth without anything on it until it starts to oxidize again (almost immediately). When you clear coat you are striping off the grease and wax and immediately spraying on a clear protective layer of paint. Take a look at any custom wheels with "polished" lips. Those are generally clear coated aluminum.
The trick with clear coat is to treat it like paint. Don't use anything that would scratch or wear it off.
It's all too much trouble for me. I prefer flat black.
This is what I did. If you have a bench grinder, take both wheels off and replace with 6" buffing wheels, (can get at any tool or hardware store) also get two sticks of polishing compound, one is red and the other is white. they are about 6" long, almost 1" in dia. and rock hard. on one wheel dress with red, the other with white. I sanded parts with 120 an 220 paper then start with green wheel to get most scratches out then final polish with white. Time spent: I polised both rear peg assy. in about 30 to 45 min. if that. Let me know if you have ??
