Has anyone done this?
Old Jun 10, 2009 | 02:41 PM
Decah's Avatar
Default Has anyone done this?
I have an 04 600rr and I have a Yosh RS-5 (carbon) slip on...I was thinking about taking the baffling out to make it louder.....Has anyone done this yet? If so will it make it sound good or like complete ***?
Old Jun 10, 2009 | 03:09 PM
cageless's Avatar
I think some of the Yoshi's have a removable baffle for just that reason.
Old Jun 10, 2009 | 03:17 PM
Decah's Avatar
how do i go about removing it for a 2004 rs-5 yosh slip on?
Old Jun 10, 2009 | 03:32 PM
cageless's Avatar
does this model have the riviets? If so you gently drill them out, and put new rivets in when done. If not just take the screw out and remove it. Or you could make the pipe a shorty.
Old Jun 10, 2009 | 03:49 PM
Decah's Avatar
it does have rivets around the cone piece at the end but it also looks like it has a screw or something in the inner middle when you look into the muffler...hmmmm i dunno !
Old Jun 10, 2009 | 04:13 PM
MartiniRossy's Avatar
Dude, I wouldn't take it all out. It'll probably sound and run like a tird. Just take out some of the packing if you want it a little louder. I did that to my M4 and it sounds sweet now. It's almost a little too loud actually.
Old Jun 10, 2009 | 05:10 PM
Decah's Avatar
how do i just take a little bit out , isnt it like a fibrous substance?
Old Jun 11, 2009 | 11:44 AM
Yes it is. It's packed in there very tight. Just take it all out and repack it not so tight.
Old Jun 11, 2009 | 01:41 PM
Decah's Avatar
thanks for the help. ill give it a try this weekend but one question.. after i drill those rivets out, how, what, and where can i get new rivets to put back in and will they fit the same as the originals?
Old Jun 12, 2009 | 08:06 AM
You'll need a rivet gun, which can be bought at pretty much any hardeware, parts or similar store. You can find rivets in the same place also. You'll want to just use the ones that fit the snuggest in the holes and are made of stainless steel or aluminum.
